Team - looking at a home charger. Popular brand here in uk is pod point.
They do two chargers. 7kw and 22kw.
Can a 2019 model 3 performance use the 22kw and charge at the suggested 60 mph.
Is 11kW true for UK cars also? Since they have a CCS Type 2 port, might UK M3s be capable of 22kW? Coincidentally I recently read a Polestar review from Europe that mentioned it charged at 22kW at curbside L2 EVSEs. I believe CCS Type 2 is capable of 3 phase AC charging. OP might want to repost their question in the UK subforum.
Charging Connectors
This link says Tesla's Type 2 cable is limited to 11kW for Model 3 and 16.5 kW for Model S & X. Not sure if that also applies to the connector.
Thanks for digging up that info. It’s what I suspected, ie that 22kW is possible through 3 phase charging at Euro voltages. Since I have access to 3 phase at work, I’m now officially jealous of 22kW charging!Looking at a wall charger for UK tesla website:
Wall Connector
The Tesla Wall Connector is the most efficient way to charge a Tesla at home — just plug in your vehicle overnight and wake up fully charged.www.tesla.com
You get the following chart, which says the same thing you typed:
Good point, and even the S & X are limited to 16.6kW, so the Wall Charger is somewhat future proofed at 22kW.If you have a model 3, its not though (and this is the model 3 subforum so I am assuming we are talking about model 3s like the OP asked about). It specifically says at the bottom "Model 3 Max charge rate on a 400V Three phase power supply is 16amps 11kW"
Older S (and X I assume) in the US could be optioned or retrofitted with dual chargers that allowed for 80A charging on a 240V 100A circuit (19.2kW charge rate).Good point, and even the S & X are limited to 16.6kW, so the Wall Charger is somewhat future proofed at 22kW.
According to the chart @jjrandorin posted, the UK Wall Charger is only capable of 7.4kW in single phase at a voltage roughly equivalent to US phase to phase voltage. I don’t believe any US spec Teslas can accept 3 phase. The US & UK spec cars & charging equipment are apples & oranges.Older S (and X I assume) in the US could be optioned or retrofitted with dual chargers that allowed for 80A charging on a 240V 100A circuit (19.2kW charge rate).
So in addition to future proofing, a 22kW wall connector would allow for full backwards compatibility. The current Tesla US wall connector can't supply those older dual charger cars at their max rate though.
