What is the range after a full charge supposed to be? (85Kw)
Discussion in 'Model S: Battery & Charging' started by Hank42, Feb 15, 2013.
  1. Hank42
    Hank42 Member
    United States - NY
    I'm curious if we are all getting a fill charge.
    I charge daily - non range mode - at about 20 Amps, and my range at the completion of charge is always 230 miles.
    At one point, I saw 240, but I think that was an anomaly. (fw 4.1 - currently at 4.2)
    What "Completed" charge range do others see?
  2. astrotoy
    astrotoy Supporting Member
    SF Bay Area
    #2 astrotoy, Feb 15, 2013
    I've had mine since Sunday. I've charged it every night at the non range mode at 40amps. I get between 235 and 237 at the completion of charge. Since I charge starting at midnight, I don't actually look at the charge until the morning, well after it has completed charging. However, it is still plugged in. I normally leave it plugged in until the first drive of the day. I don't plug it back in until midnight (when the lowest TOU charges begin - right now it is less than 5 cents/khr at off-peak times).
  3. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    As I recall, I was getting 235 when on the other system: I prefer to use "ideal" miles for several reasons. Ideal miles charge to 275 in Standard and 305 in Range as per yesterday. You can convert these, I would suppose, to the other system, or someone else will. I have a headache and can't think right now.
  4. montgom626
    montgom626 Active Member
    Doesn't range depend partly on your prior use? I know my ICE predicts range based upon my prior use.
  5. Sparrow
    Sparrow S105/ Roadster 189
    Marietta, GA
    On a Standard charge the rated range for me is usually 241 right after charging is complete. It settles into the upper 230s within a few hours. With the vampire load, you almost have to ask how long after the charge is complete do you check your voltage.
  6. markb1
    markb1 Active Member
    San Diego, CA
    On my 60kWh pack (yeah, I guess I'm off topic), I get 190 standard and 197 range (rated miles). But I noticed when I ranged charged that it continued to charge for a while after I hit 197, and I had to drive about 10 miles before it dropped below 197. What's up with that?
  7. derekt75
    derekt75 Member
    San Jose, CA
    Agreed. 240 or 241 when it stops. somewhere in the 230s when I unplug it. after the vampire load sucks enough power, I think it starts charging again as I've never seen it below 230 even over the weekend.
  8. spatterso911
    spatterso911 MSP#7577 **--** MX#1891
    Rancho Cucamonga, CA
    I'm getting average 241, several times after recharging more than 100 miles, I've seen 244, but if the car sits, vampire load takes the rated miles down to about 236 or so from the night before. If I restart charging, it usually recharges to 241 in about 10-15 minutes though. I'm glad I can do this remotely now :)
  9. spatterso911
    Here is the current state, at this very moment...
  10. FlasherZ
    Did a range mode charge this morning. It showed 267 miles when I got in it.
    My car completes a standard mode charge at 240-241 miles (then usually loses 3-5 miles overnight).
  11. tezco
    tezco Sig P85
    Colorado
    If I look at the screen soon after a standard top-off charge, I've got 273 ideal miles, but it's down to about 258 ideal 24 hours later.
  12. jhs_7645
    jhs_7645 VIN: #3305
    Camas, WA
    What everybody should expect on average is 238.5 : 265 (EPA rated range at 100% full) * .9 (normal charge fills to 90%) == 238.5
  13. contaygious
    contaygious Active Member
    Marina, San Francisco
    231 normal and 271 range
  14. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I get (right after charge completes):
    Standard
    Ideal 435 km / 272 miles
    Rated 385 km / 241 miles
    Range
    Ideal 481 km / 301 miles
    Rated 425 range / 266 miles
  15. rlawson4
    rlawson4 Member
    Atlanta Georgia
    I get 238-241 and 265 Range *the one time I charged Range
    When it's cool out (by Atlanta standards) It will be at 236 in the morning.
  16. Cattledog
    Cattledog Active Member
    San Antonio, TX
    238-241, 266 the two times I did a max charge.
  17. rash67
    rash67 New Member
    Fremont, California, United States
    cattledog's info seems to be what i'd expect with standard charge. It's a small variance around .85 (or .9, I was told .85, but jhs may be right). It's all about battery memory if my memory serves...
  18. mnx
    mnx 2013 P85
    Ancaster, Canada
    I usually see 385km rated for a full standard charge but saw 387km the other the for the first time.
  19. Martini
    Martini Member
    Paris, France, France
    Does anyone know if individual cells in the battery pack are tested before assembly to "balance" the pack. One could expect tiny variations in capacity between cells.
  20. Tempus
    Tempus Member
    Virginia
    Thats interesting. Ive never seen more than 185 on a standard charge with my 60. I wonder if the difference is the vampire load. I havent been motivated to check the car at 2 am for the charge level when it finishes charging thus far.
