Only because I though most people would carry their UMC with them. But that's only if there is charging provided at work, which seems to be a minority.Yeah, it seems you left out the most common choice for whatever reason, as shown in the largest number of votes out of 7 choices being "Other".
4 years with mine now, and I also leave my UMC permanently plugged into the 14-50 outlet in the garage.
I've found RV parks handy for charging out in the boondocks. The UMC with the 14-50 plug comes in handy here. I always take it with me on trips. Also, in a pinch, most hotel A/C units will give 16 amps at 240 volts. I have an adapter for this.$245 for an electrician to install a 14-50 outlet and I leave the UMC plugged into it.
In my case though I had the wiring all in place for it.
The UMC will do you almost no good out and about.
Almost all public chargers are J1772. Bring your J1772 adapter and you are good to go.
Thanks for your helpful reply!Some tips I’ve read when researching charging specifics:
1. Try to keep your average state of charge (SOC) around 50% for a given day. 60-40, 70-30, etc. (TEDx)
2. Charge so your battery reaches the desired SOC shortly before driving for best performance. This helps even more in cold climates. (Manual)
3. Avoid 100% and 0% if possible for longest battery life.
4. Charging to above 94% every six months will help keep cells balanced. (TMC)
Disagree, even if based on a sample size of one. We have six conveniently located 115v outlets, with every EV owner bringing their own EVSE.Yeah, but once again, the typical 'charging provided at work' doesn't need the UMC, just the J1772
Endless options. At endless price points!But hey, when I (or some of you) said there are many options, wasn't that the truth?
That sounds like a real pain. I think I'd try to avoid investing in anything that's not going to be semi-permanent, and any long term solution that involves daily adapter and cord shuffling would be sub-par for sure. In your situation, I think I'd just charge at 120V until a preferred, more permanent setup can be decided upon. Then put in a Tesla Wall Connector.One forward-thinking electrician offered to install a new breaker and hook up a super-duper extension cord to it terminating with a NEMA 14-50, all within code. Says it's a popular option with people who need flexible and infrequent additional power supply such as for entertaining. Says when not in use, kill the breaker and coil up the cord on the ground in the side yard, under the panel.
Aside from obviously costing less (1 hr labor + cost of cord, which he promised to price for me), it solves two dilemmas. Outside vs inside wiring? Neither. And inside or outside of garage hookup. I have not yet figured out which I prefer and which I will be allowed to do, and whether my situation will change as to how many and what kind of cars I will have, how cluttered the garage will get and which side I will be parking on. The extension cord takes all these variables out of the equation. Leaving just two questions to ponder:
Will wife approve a loose cord running across front steps from side yard to garage overnight, and will I hate having to not just constantly replug, but also wind up the cord when not in use. Something about this prospect brings the coolness factor of owning a Tesla down by about 60%.
I have free charging at work and its a J1772, so I never use my UMC.Only because I though most people would carry their UMC with them. But that's only if there is charging provided at work, which seems to be a minority.
Are you not worried about being caught out of the house without the UMC? I guess not...
If you were able to connect the HPWC, why can't you trip the main breaker and connect to the panel? That part is much easier to do.I bought a new HPWC off of eBay with 20% coupon = $420. I called around and got quotes of $2,200 - $2,350 from 3 different electricians for about 95ft wiring installation. Too much!
I bought 100ft of 4 guage romex wire, circuit breaker, etc. for about $500 from an electrical supply store. I ran the wire myself (damn the 4 guage romex is heavy!). An electrician will come and hook it up to the panel for about $100 this week.
So it would cost me about $1,000 all in for the HPWC system for me.
The answer is to get off tiered rates.Where are you getting 10 cents? On a separate EV meter maybe, but he is on the same meter. His generous household usage without the car puts him in the highest price tier at 45 cents if he were to charge the car at home.
