What is your Powerwall 2 charging rate?
eml2
252
192
Massachusetts
Whatever mode i am in , i only push 1.7kwh to the battery : Battery backup or Self powered
I wonder if it depend of the setup or something else ?
After you change the mode to self-powered in the app, did you wait long enough for the change to propagate to your PW/Gateway? It can take up to an hour.
Parzival
148
98
Houston, TX
Mine are charging at 11kW right now, and I have never seen any charge restriction. I have also never seen them charge from the grid. I was told they will never do that (aside from a bug in an older software release that allowed it.)
It may be worth noting that I have not played with backup-only mode. My feeling is that keeping the Powerwalls charged to 100% all the time can't be good for them.
Shygar
925
517
Pleasant Hill, CA
They lose 1% a day if you don't charge them. I'm still waiting on PG&E to give the PTO so I'm stuck in backup mode with solar off.
Parzival
148
98
Houston, TX
Yes, but what I mean is, keeping them charged near 100% all the time is likely going to cause them to lose storage capacity faster than if you cycle them and keep them closer to the sweet spot of 50%. I'm sure Tesla has modeled this extensively, but they're not sharing it, even internally.
I got my PTO last Thursday, and I've been net exporting since, which is both nice and annoying because I won't get credit for exported energy for another month. The utility gets to sell it to my neighbors and I get nothing but the satisfaction of offsetting a small amount of dirty generation.
kevinwithnall
33
94
Sydney Australia
I seem to be limited to 10kw with 2 powerwalls.
Frankman60
415
86
San Diego, CA
Wow, there is a pretty big range that people are reporting for the maximum PW charge rate. For the posters that are experiencing a charge rate of less than 5 kW per PW, did Tesla install your PWs or were the PWs installed by a non-Tesla contractor? I”m thinking that the limitation has to do with how the PWs were installed and I am going to assume that Tesla installers know what the charge rate should be and are most likely to install and configure the PWs properly.
cwied
867
616
San Mateo, CA
I'm currently getting a maximum charge rate of about 1.7 kW per PW, and Tesla installed the Powerwalls. I haven't gotten the official PTO from PG&E, though. I've heard mention that that may affect the maximum charge rate for some reason (can't find the reference, unfortunately).
miimura
5,989
5,567
Los Altos, CA
I thought that installations without solar were limited to charging at 1.7kW per Powerwall.
cwied
867
616
San Mateo, CA
Ah, interesting. I'm not in backup-only mode, but I do set my backup reserve to 100% during off-peak times. I guess I should set it to something lower when charging.
liuping
2,241
895
San Diego
I do have solar, though. It actually looks like I'm peaking out at 3.3 kW.
maybe there is a limit it will send to the powerwall, when the house is still using power.
Try discharging to a higher percent the day before, so it's still charging after 1pm, when you solar minus the home usage is more than 3.3kW.
TomDiego
42
34
San Diego, CA
I do have solar, though. It actually looks like I'm peaking out at 3.3 kW. Here is an example:
The way that I read your "Battery State" you appear to be maxing out at 10kW. It appears that you have the "Battery State" as an area rather than a line. You also have "Solar Generation" as a line instead of an area. My "Battery State" line shows it maxing out at 10kW, same as yours. I did my PVOutput setup based on the instructions on the Mike's Gear website: Monitoring Tesla’s Powerwall2 on PVOutput.org. This is how he set up the parameters. With this parameter setup it looks a lot like the Tesla app but with the added Battery State line:
This is what my output looks like:
Reactions: SoundDaTrumpet
