What kind of outlet is this?
Hi folks. What kind of outlet is this (found it in my garage), and what kind of adapter should I buy? Thanks!
Thank you! Maybe I’ll wait on the $500 tester wall charger. (How much is the install for that?)
Far too many variables to say, but the HPWC connected to those same wires(presuming they are sized for a 6-20 load) will get you no more charging speed at all. That 6-20 should get you around 16 mi/hr of charge rate, which should be plenty for most users. Don't forget the 30% tax credit for new charging equipment/install.
I imagine an electrician would do such an install(direct replacement) for $200 or less. OTOH, if that's currently in a garage the electrician is likely to want to replace the wiring with conduit-based wiring(or MAYBE run that current wiring through conduit below 7') since NMB isn't supposed to be accessible(I think the rule is 'below 7 feet above the floor its gotta be in a wall', but don't quote me on that).
6-20 is a great, cheap option especially if you already have one available! 16 mph is generally plenty for most people.
However, it may be worthwhile to swap the outlet out for a new, industrial grade one like the Hubbell part #HBL5461. Tesla recommends a high quality industrial grade outlet. Lots of color choices if you don't like the brown one in the link below also.
Reactions: MitchMitch
Awesome, thank you!
Reactions: Jeremy3292
