  • The final cut of TMC Podcast #29 is available now with topics time-stamped. We discussed the Tesla Cybertruck's expected 1 MW Ultra-Fast Charging capability, the Tesla Semi Delivery Event, the coming Model 3 refresh (project "Highland"), and more. You can watch it now on YouTube.
What kind of windshield washer fluid does Model 3 Use?
I had a mobile service done in my garage because the driver side washer does not squirt fluid. Service tech pressed the stick a few times and quickly diagnosed the assembly folk did not connect the fluid hose. Push it in and it worked immediately. Easy fix. However, after I backed out the car, I have several puddle of blue liquid on my light color epoxy coated floor and it won't come off. Normally people do not activate windshield washer in their garage but in this case, I was wondering what to use to get rid of the stain.
Matsayz
1,307
1,162
Las Vegas
He's not asking for a refill--he wants to know how to get the stain off of his garage floor.
The title and then the body of the post conflict. It’s only washer fluid. Again, Tesla isn’t using some super high grade stuff. I’ll admit it’s got a lot of blue dye in it but it’s still only washer fluid. Grab a can of brake cleaner if it’s really not coming up but water and a sponge should get rid of it.
Tesla has to pay to repair your floor as Tesla did not take all reasonable care to protect your garage floor while working on your Tesla.
Reactions: jebinc and Matsayz
Uncle Paul
6,299
7,645
Canyon Lake,CA
I noticed that Tesla uses the same type of windshield wiper fluid as Mercedes.
It is super effective at cleaning road grime off windshields, but had a thick blue tint that needs to be manually wiped off A pillars and other painted areas of your car.
Much stronger stuff than the watery stuff available at auto stores.
Mercedes sells it as an ultra strong additive that needs to be diluted with lots of water when refilling.
KInda one ounce to 2 quarts.
KenC
4,676
4,395
Maine
It was so strong, they sometimes poured it into the urea tanks of their "blue" diesels, undiluted! ;)
LOL. I got you guys to read my post, didn't I? Two points in the contents. Tesla left a windshield washer hose unconnected and delivered the car. They use high stain washer and that dripped on my garage floor that won't remove. Btw, don't you guys have been things to do but to argue about the title or a posting and tried to split hair?
srs5694
1,545
2,069
Woonsocket, RI
Two points:
  • Did it get the right people to read the post? Perhaps an expert on removing stains hasn't read this thread because s/he thought the post was asking for recommendations of what sort of wiper fluid to use, and this hypothetical expert isn't interested in that subject.
  • When a forum's posts have misleading titles, that makes the forum less usable for everybody, which can drive away participants. Your title isn't all that bad, but properly titling threads helps make the forum useful.
Reactions: Dr. J and Matsayz
Just use some vinegar mixed warm (a bit hot is fine too) water & a rag to clean up the mess on your epoxied garage floor. If it too doesn't work, then sorry to say, but you'll just need to live with it... after all it's just a garage floor & it's going to experience such spills.
