To date, the North America Model Y has traditionally had the 980 rear motor for the Performance and the 990 motor for the Long Range. But my 2023 LR has a new hairpin motor called the 4D1 (which is supposed to be an upgrade to the 980 Performance motor). It turns out there are at least a few other 2023 MY LRs out there with the same 4D1 motor and I believe they are all Austin builds with VINs that erroneously identify the LR as a Performance (F in position 8). So far I am only aware of cars that VIN with PA048 or PA049. As a side note, these new Performance motors are not providing any extra boost, since the LR software is still limiting their capabilities.
It would be interesting to see what motors others are receiving in their 2023 MY. The video below shows how to locate the 980 and 990 motor in a Model 3, but the Model Y will be in the same place (you don't need to jack the vehicle). My 4D1 motor's placard. however, is in a slightly different location - just under the boot that connects to the motor (see the attached image). For the 4D1 photo, I found it best to use my cell phone camera set to flash with a 10 second timer. After starting the timer, I inserted it under the vehicle from the rear of the back left tire (not forward of the tire), then placed it up and angled towards the placard location.
Please post your results similar to my format below (you can exclude last 3 digits of VIN):
December 2022 Austin Build LR, 7SAYGDEF4PA049XXX, 4D1 Motor
