I assume you mean 10mm gap? 10cm is huge. That can't be correct.A friend was on the release event and it is a 10 cm gap.
IMG_0179 | Flickr - Photo Sharing!I assume you mean 10mm gap? 10cm is huge. That can't be correct.
I agree that 10mm (1 cm) seems large. Can anyone else confirm that? Doesn't sound right to me.
So how is the t mounted in the summer? [sorry]I would be more worried about the gap below the hood, where the T is mounted in the winter.
I looked through those photos. The first photo appears to show the front Tesla "T" sticks out slightly. I don't see how that is going to cause a problem. There is a close up photo of the "T" that is blurred and it is not clear what supports the "T". But I doubt that is empty space. Suspect it is gloss black plastic.
Random Model X sightings - Page 35I looked through those photos. The first photo appears to show the front Tesla "T" sticks out slightly. I don't see how that is going to cause a problem. There is a close up photo of the "T" that is blurred and it is not clear what supports the "T". But I doubt that is empty space. Suspect it is gloss black plastic.
Thank you for the link to a closeup, in focus image of the X front "T". Now I see that it appears to stand out by about an inch from the rear of that cavity. I do not see what the "10 cm" distance posted earlier refers to.
If that cavity is that deep, then I wonder what the purpose of it is. Seems odd to me. An air intake for the HVAC?
This is proving to be quite an interesting discussion about an intriguing feature of the X. Thanks for your comments. I'm looking forward to seeing one in my local Tesla showroom, sticking my arm in that cavity, and asking the staff "What is this hole for?" [emoji3]I don't think it's an air intake, but rather that it has to do with aerodynamics, perhaps directing frontal airflow better than a rounded front. Or as sigurdi suggests a type of front spoiler function to increase traction on the front wheels during higher speeds.
I would kindly ask the mod to carve off this discussion into its own thread as I agree it is a good topic.This is proving to be quite an interesting discussion about an intriguing feature of the X. Thanks for your comments. I'm looking forward to seeing one in my local Tesla showroom, sticking my arm in that cavity, and asking the staff "What is this hole for?" [emoji3]
It surely has a specific purpose.
It is probably best to investigate personally, but it surely would be most impressive if the "T" glowed and lit up the cavity and made it look like it was floating. And maybe is able to change its color due to preference or even amount of torque being applied (would be cool to see it go intense red with full power)
For the functionality, with such a low Cd, I can't imagine it would increase drag, but decrease drag and does serve a functional purpose. Should be fairly easy to look and see if the cavity is connected to anything.
