Thank you Jerry! Very informative. This information is new to me. Is it consistent with the Dahl lecture?
If your battery is plugged in the car will pull from your wall connector for the housekeeping current it needs to function. These are not high voltage requirements like charging your battery is so you don't need to worry about TOU or peak hour limitations. If it's not plugged in, it will pull from your 12v battery which puts unnecessary strain on that battery. That's why Tesla recommends to "always keep your car plugged in".
I think you may be conflating two things with that answer. The charge cable can only deliver 240V or 120V AC power from your wall outlet. The onboard charger can only convert that AC power to high voltage DC and feed it to the main battery. All of the accessories, including onboard electronics work off the 12V battery, which in turn is periodically re-charged from the main battery via a DC to DC voltage converter.If your battery is plugged in the car will pull from your wall connector for the housekeeping current it needs to function. These are not high voltage requirements like charging your battery is so you don't need to worry about TOU or peak hour limitations. If it's not plugged in, it will pull from your 12v battery which puts unnecessary strain on that battery. That's why Tesla recommends to "always keep your car plugged in".
I never said it will draw power constantly to maintain the main battery level. I also didn't say it would draw from the grid if the battery level is higher than the desired limit. I have seen the HVAC turn on while parked and not plugged in on hot days. Whether that's drawing from the main battery or 12v I'm not sure. What I'm saying is there's a couple of good reasons to always keep the car plugged in which also is what Tesla advises. I was incorrect in stating that the grid is directly charging the 12v. The battery does that as you and @brucet999 state.That is not correct. The car will not draw power from the grid (when plugged in) to power 'housekeeping'. It will only draw power from the grid if you turn on the heater/AC or when the battery is charging. If the battery level (from vampire drain) drops below the set charge level the car will initiate the charger and bring it up to the set level. Depending on how much your vampire drain is it usually takes 2 to 3 days before the battery level drops enough below the set value to initiate the charge again.
It does not draw power randomly for other reasons. It does not draw power constantly to maintain the battery level. If the battery level is higher than the charge limit, it will not draw power from the grid until the battery level has dropped below.
I keep Teslafi.com log my car 24/7 and I have never see the car draw power from the grid for any other reasons other than to charge the battery or run the heater/AC.
HVAC always runs on high voltage, not 12V.I have seen the HVAC turn on while parked and not plugged in on hot days. Whether that's drawing from the main battery or 12v I'm not sure.
Mike, are you saying it does not need to be plugged in for the DC converter to come on to top off the 12v?All other loads are powered from the 12v battery, and the DC-DC converter will come on from time to time to keep the 12v topped up from the main pack, but when this happens it does not draw shore power.
Got it, however it does make me question why Tesla advises owners to plug in everyday unless you need the electrons the next day. I can go a week without charging as long as I know it's not hurting anything.Exactly. The DC-DC converter is using the main battery pack as a source and as it's only source. The 12 Volt battery is entirely charged/maintained by the DC-DC converter that is drawing from the main battery. There is no separate or dedicated charger that draws from the grid and charges the 12 Volt battery.That's why it doesn't matter for the 12 Volt system weather the car is plugged in or not. It's getting it's power from the main battery whenever it needs. This is the main cause for the so called 'vampire drain'.
The heater and AC is also using only the main battery as it's power source. (It runs on the same voltage as the main battery so no DC-DC converter is necessary). When you turn on the AC/heater even while the car is plugged in, the power comes from the main battery. When the car is plugged in, the car will turn on the charger and recharge the main battery at the same power rate that is taken by the AC/heater. In other words, it is making up exactly what the AC/heater uses, so there is no net loss. Still there is never a direct connection from the grid to the AC/heater or any other system in the car. Everything the car needs is taken from the main battery and the chargers recharge the main battery as needed.
The reason is that you can build a heater/AC system only to run from either DC or AC, not both. So everything in the car is made for DC current as it is provided by the main battery. The car's chargers are taking the AC current from the grid and convert them to DC current to charge the main battery.
I hope that clears up some of the confusion.
Not correct. The smaller the cycles, the longer the battery will last. If you are going for several weeks or months, then set the slider to 50%. For normal use plug in every day. It appears from the posts in this forum that 90% with the occasional 95% charge to engage the charging circuits (they engage at 93%) gives the most life.
The way it works is that if you charge from 0 to 100 all the time, you'll get somewhere around 300 cycles (this number subject to correction, but it's not very many). As the amount of daily charge decreases as a percentage of the battery the number of charges goes way up--not linear, but exponentially. So you should plug it in whenever possible to maximize battery life.
How to Prolong Lithium-based Batteries - Battery UniversityI have read these forums extensively. I have also read the Dahl study, which contradicts this somewhat. Dahl's main theory is that it is the amount of time at high SOCs as well as the temperature are the two factors, taken together, that lead to battery wear. There is a section in there were he talks about "beating the clock" by cycling to 100% and immediately discharging. He also told another member, in a follow up question, that there is a charge state where being over a certain voltage could cause harm. I believe that state is over 80%.
Yours is the only place I have seen this theory about size of the cycles. Where do you get your info?
Might I ask --
Outstanding information! I'm going to quit worrying about a lot of battery issues that I've been worrying about. Thank you.
David have you written elsewhere about your history with EVs? I'd like to read it.
Edit: I see that you have 7 videos on YouTube (looking at your YouTube: Sharkcookie.ev). I'm going to look at all of them before I pester you (or anyone else here) with questions. Many thanks.
Why do you say balancing is a myth? Every two or three months my 90D will lose a couple of miles that is easily recalibrated by driving it down to 10-20% and then charging up to 93-100%. This was all very well documented in wk057's research. It seems to be more a software algorithm thing in the BMS than a battery issue.Let me answer some of your questions. I had my Model S for 3 years and 115,000 miles. I also have access to the battery data thought the CAN bus so I was able to learn what the battery does and what the car does. I also bought my first EV back in 1992 and kept up with battery development all those years.
Lithium batteries age (degrade) faster with higher temperatures and with higher state of charge. So it's not good to keep the batteries hot nor is it good to keep them fully charged all the time. Neither is the case in an EV, especially not with a Tesla as it keep the battery temperature within a healthy level without us having to do anything. And if you keep the charge level to 90% or lower you are totally on the save side. Charging to 100% is not bad. Keeping the battery at 100% for longer is bad. So no worries about charging fully and then start driving. That's fine.
Lithium batteries have no memory effect. Battery capacity is not measurable like say water in a glass. How much capacity is left is a combination of voltage and temperature and measuring how much energy was added in and how much was taken out. It's not 100% accurate and it gets especially difficult to calculate the exact capacity when the battery is charged and discharged partially for a while. The calculations errors just add up. It can easily be calibrated by charging to 100%. It's not memory effect.
Balancing is another one of these myths that are overly discussed and misinformation is spread. When batteries are connected in series, they need to have the same capacity or else the one cell with the lowest capacity will limit all the other cells to the same. Again, that is something that Tesla takes care of in a very sophisticated way without needing any attention or us doing anything. My battery pack is over three years old and has 115,000 miles on it and the differences between the modules is less than 0.1%. That is amazingly good and for such an 'old' and much used battery. My battery has aprox 460 full cycles on it and lost about 7% capacity. But keep in mind that most of the capacity loss (degradation) happens in the beginning and then slows down over time/age. In other words, in another 3 years from now my battery won't have lost 14% but probably much less because degradation slows down.
Fast charging does not hurt the battery. I have used Superchargers for more than half my miles driven and my degradation is above average. I also live in a rather warm climate and drive a lot in hot climates (California, Arizona, Nevada).
