What should the charge rate be set at for HPWC
I have a dedicated 100 amp service and the HWPC can be set up to charge at up to 80 amps.
I know the M3 won't handle the higher amps, but will it automatically adjust to the lower rate?
I'd like to have it set at the higher rate should I buy a model S in the future.
If you have it on a dedicated 100amp circuit, then set it to 80 amps. The car will only take what it can handle.
An older model S with dual chargers can take the full 80. A current gen mode S can take either 48 or 72 depending on config.
If you have the HPWC on a 100 amp breaker with proper wiring, then the interior switch settings inside the HPWC should be set for 100 amp breaker / 80 amp charging.
No adjustments in the car are necessary -- all Telsa models will charge appropriately.
Reactions: Rocky_H
