What size spacers for a more aggressive fitment on the stock 19" sport wheels?
Hello all!
What size spacers would you run front/rear to get a more aggressive fitment on stock height, stock 19" sport wheels on an AWD?
Thanks for any help!
coming back to this just in case you still needed some help,
Depending on how more aggressive you wanted to go
10mm spacers would push the wheel out a little bit less than half an inch, but with a 10mm spacer you will more likely need extended studs
15mm spacer is slightly more than half an inch, if you were looking at this option we suggest an adapter that way you wont need extended studs.
those 2 options on a stock body will have the wheel out at the fender, or slightly past. Again it really depends on how "aggressive" you wanted to go.
