Any updates on your project? Asking since I am looking at a similar system. Currently considering 44 330W panels with tow SolarEdge inverters. Have two 200A panels and want to backup both. Probably just 4 PW's for me.
Some plans were put into county and rejected because they wanted on blade disconnect per battery. Holidays slowed things down. I have been requesting to be involved in the plan reviews since I found issues with the first ones, and continue to find issues. Makes sense since I have a very complicated install. We all got together on a phone conference yesterday and my generator has continued to be not dealt with correctly, meaning, the solar and batteries must be in a generation panel before my 2 generator automatic transfer switches or things could be burned up.
Since you already have two SE inverters things will be easier for you since my 47 panels are in one inverter.
So, you just need to decide how flexible you want to make your setup.
But, the first big issue to deal with is where do you put the batteries? Meaning, since Tesla does not have a 400 amp TEG, you may have to make trade offs. Also are you going to do whole house backup, or split to critical vs non critical. This decisions drives one in one direction. It also can mean, as for me, that the amount of batteries are not what they seem.
In my case, I am doing whole house. But, I have critical loads in both subpanels. So, lets say I get 5 batteries. Where do I put them.
My garage panel contains all my mini split heat pump stuff. So for all practical purposes, I am backing up two homes. Since it seems I use more suds on the heat pumps subpanel, I would put the odd extra there. But one needs to make sure one have enough suds to overcome the startup loads.
Another decision is how do you connect your inverters and batteries. There is space and parts for the TEG to connect up to 6 batteries. Since I want the ability to maybe expand things in the future, we are going to use seperate 200 amp panels for generation panels, rather than connecting into the TEG and limit what could be done in the future. No one else would ever do this, but I always like to be ready for future changes if needed.
Hoping to get back updated drawings soon so I can make another look.
So, most folks never get into the details I am getting into. Most do not have to worry that a generator works also. But doing my best to make sure I have no issues once things start being installed. I am out measuring now to make sure I can fit the batteries all side by side.
Not sure where all the disconnects are going. Going to be a ugly install of boxes.
