What was the smaller semi???
Discussion in 'Semi' started by Erleichda, Nov 17, 2017.
Tags:
  1. Erleichda
    Erleichda Member
    Portland, OR
    Why has nobody asked about the black smaller Semi that was on stage???? Any info out there?
  2. ChadS
    ChadS Last tank of gas: March 2009
    Redmond, WA
    It clearly had a lower roof, along with a lower trailer.
    But I couldn't tell if it was otherwise the same size, or really smaller. It looked a little smaller, but I suspect it was just 2-D perspective (I was not there in person) given that it was parked farther away and a darker color.
    I too am interested if there were significant differences...
  3. drmichaels9
    drmichaels9 Member
    Newark, New Jersey
    It could be two different sizes depending on the customer needs. Thoughts?
  4. Tam
    Tam Well-Known Member
    Visalia, CA
    I think one with room for sleeping while the other one is for a day job and not for sleeping in.
  5. MarcusMaximus
    MarcusMaximus Active Member
    Los Gatos
    I don't think it so much had a lower roof, as much as it was just lacking that hood section(see the picture from electrek from a while ago and it's clear how that works). I suspect the two vehicles are the 500 mile range and 300 mile range versions
  6. ChadS
    Redmond, WA
    I am pretty sure the roof of the darker one is lower:
    In this picture it does otherwise look the same size, however.
  7. DriveMe
    DriveMe Member
    NE OH
    I think it’s the same truck, just a different spoiler on the cabin roof to match the height of the trailer for aerodynamics.
    • Like x 10
  8. SMAlset
    SMAlset Well-Known Member
    SF Bay Area
    I thought I read that current version doesn't have a sleeper area.
    If I'm not mistaken I believe it's the same cab on both the white and matte black/gray semis. Seem to recall that at one point in time Telsa said there was a higher profile roof hood for larger containers so that either size trailer with the cab would be aerodynamic.
  9. ChadS
    Redmond, WA
    Ah. The top part is called a hood?
    Anyways, it seems there is not much of interest here. Bummer.
  10. TaoJones
    TaoJones Beyond Driven
    The Americas
    Looked like a solid candidate for local hauling and deliveries.
  11. mongo
    mongo Well-Known Member
    Michigan
    Ha! That's not a real box, it's screwed together OSB painted brown to the hide the Roadster on the car hauler trailer. tesla-semi_26_close_up.jpg
  12. Tiger
    Tiger Active Member
    Estonia
  13. buttershrimp
    buttershrimp Click my signature to Go Mad Max Mode
    ATX
    Here's some closeup video I took last night of the smaller semi... hope you like it. The back of this thing is unreal.
    • Like x 4
  14. ohmman
    ohmman Plaid-ish Moderator
    North Bay, CA
    So the smaller semi is just the semi without the "hood." Got it. I guess that works for trailers that are shorter, like the ones I see in the city. If only it could use a Supercharger (instead of a Megacharger), one could see using it to haul a sweet modified camping trailer. And by one, I mean me.
    • Like x 6
  15. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    It's really an optical illusion -- the "smaller" semi really looked like a "mini" version of the white, larger one. But the tractor parts of both are the same size.. just one with a bigger hood and taller trailer. Until I looked really close, I thought they were two different products (sizes), and was wondering why Elon didn't talk about the "small semi" right behind him. Now it all makes sense.
  16. WannabeOwner
    WannabeOwner Well-Known Member
    Suffolk, UK
    Wing mirrors on the smaller one, cameras on the bigger one, will be interesting to see how that plays out (presumably have to shift eye-focus looking at screen instead of a mirror - but I don't know if that's a real-life problem, or not, I don't seem to have difficulty switching focus to look at the dashboard ... but I've read people saying that the rear view mirror on Bolt, which has either-or Mirror / Screen, takes some getting used to (i.e. focus-change) in Screen mode, but I haven't seen one to experience it ... yet :) )
  17. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I think the smaller Semi with a smaller trailer is designed for the European market where commercial trucks are smaller than in the US, but it could be used in the US for smaller loads.
  18. electracity
    electracity Active Member
    Tesla showed one truck.
    The gray truck not only has a lower aero roof extension, but is also missing the wings that fill in the gap between tractor and trailer.
    The truck is certainly small enough that Tesla could make a lower power two motor "Class 7" version for Europe. They can also extend the rail and make a non-articulated box truck. Aft of the battery pack this truck, like most trucks, is highly modifiable. The fact that the cab is relatively small and low yet fills the class 8 role in the U.S. is undoubtedly a strategic choice.
    They won't sell to the owner/operator market in the U.S. with this truck, and they probably don't care.
  19. WannabeOwner
    Suffolk, UK
    So that would make it suitable for loads that aren't shaped like boxes? Like Gas tankers for example :D
  20. cpa
    cpa Active Member
    Central Valley
    You will have to get your Class A California Driver License, Ohmman, before you will be able to take your new baby on the road. :(
