AlanSubie4Life
Efficiency Obsessed Member
Does that formulation even hold true for electric drives?
Yes.
OK. A little math, then. Torque on my 2015 P90DL is 713 ft-lbs. Fully wound out, I'm told, the motors are spinning at around 16,000 RPM. 713 x 16,000 = 11,408,000 horsepower. Dayum! The usual HP figure for this car is 762. Of course it's possible my calculator is busted. And math and I never did get along. Can someone double check my numbers?Yes.
Of course.Well, I did not divide by 5252, which is required when torque is specified in lb-ft. But I also did not specify units for the torque so that is cool. For my argument above all that mattered was the proportionality anyway, not the units.
And your motor does not generate that torque at that RPM; that is the peak torque.
agnostic of motor type. both go spinny spinny.Does that formulation even hold true for electric drives?
probably was issued marginal torque improvement at lower revs, that tapers off.Yeah, but the HP line should have a higher slope as well, below 5k RPM, since HP = Torque *RPM, and we know Torque increased (slope of HP curve = Torque...). But the HP curves only deviate at higher RPM which does not make sense.
You can see earlier in this thread the instrumented data (accelerometer and VBOX) shows 5% torque increase basically all the way up, eventually tapering off at very high speed.probably was issued marginal torque improvement at lower revs, that tapers off.
btw, qualitatively, this electric motor with flat/constant torque output is way overblown. atleast compared to what i was conditioned to believe. modern engines have torque curves that are just as flat or even better (over their limited range).
of course, the advantage of these electric motors is how well they maintain it for how long....maintaining decent torque output at those stratigraphic revs is something motorcycle engines can only dream of
I plotted (poorly) the HP and TQ curves from MPP's 90% SoC Dyno of the LR RWD for comparison. Looking at all three, it is amazing how flat the AWD HP curve is from 5k to 11k RPM.
Take a look at the provided graphs, and by the way it's flat horsepower curves that are being discussed not flat torque curves. It is hardly hype or overblown misrepresentation to suggest that there's really no comparison between the flat horsepower curve generated by the Tesla especially the all-wheel drive motor which is amazingly flat, compared to any gasoline engine ever made. So the notion that it's overblown seems completely unsubstantiated. If you had an internal combustion engine capable of this flat a horsepower curve, you would have gotten a Nobel.
wait...what...? The torque is basically completely flat from 4mph all the way up to close to 45mph! Ignore the dyno curves below 3000rpm (that is nonsense data). It is that crazy torque at low RPM that people talk about with electric motors... and for the Model 3 it is crazy after about 2-3mph (a few hundred RPM). Yes, torque starts dropping significantly at higher speeds, due to battery and motor limits.
ignored that the lower speeds is artificially hampered due to traction,
you could tune a motor to produce a flat hp curve - but why would anyone ever want to?
in any given gear, motor speed is linear to road speed. at any road speed (and thus at any motor rpm), you would want the maximum power available for acceleration. that means maximum torque.
at any motor speed, maximum torque is desirable. a flat hp curve requires a monotonically declining torque curve. nobody wants that.
if the ghost of alfred nobel and michael faraday and nikola tesla and nick otto and bosch and benz and atkinson all collaborated together, their ideal engine would produce equal torque at all speeds. be the engine electric or combustion
reduced weight is good. reduced complexity is good. simpler transmissions are good - if so enabled by the motor.That's an impressive collection of geniuses but not all of them together could likely create a constant torque engine at any speed - might be physically impossible in any case. What you're leaving out of your analysis is the advantage of a flat horsepower curve compared to a flat torque curve and it's a big one - you obviate the need for a transmission. That means reduced parasitic loss, reduced complexity, reduced weight, reduced mtbf and last but not least reduced cost. You can't do that with an internal combustion engine. If you could somebody already would have. I'm curious do you actually own a Tesla? You seem fond of the liabilities of ICE. But all the spinning in the world (pun not intended!) doesn't reduce their liabilities.
