You have lots of nice panels, and I wouldn't take any bets on how well they would do with the impact from a frond dropping on them.
Yeah, this is a concern too. It drops it’s fronds periodically and it’s fruits frequently. The fruits often land on the roof and roll down and when I first moved into this house I was convinced that I had a rodent or something living in the attic until I finally realized it was just the palm fruits rolling down the roof.
pluck the leaves?
(A good trim may reduce the shading)
Yeah, I can remove some of the lower branches that are on their way to falling off, but it’s not an easy task. Even the lower branches are attached a good 20ish feet above the ground, so it takes a not so safe combination of a ladder and a pole saw to remove them. Additionally I suspect that most of the shading is coming from the upper branches, which are the healthy ones that I wouldn’t really want to remove anyway.
Palm owner and lover here and palm roots aren’t likely going to be a problem. They pretty much are more of a big ball close to the trunk. And they are not like the typical hardened tree roots that break apart concrete and underground plumbing. Palms are related to the grass family. Palms are used in fact for areas that have limited bed space and can be planted close to walkways and such.
That’s good to know, thanks.
The issue as I see it with your palm, is that a queen?
I believe it is a queen. It came with the house, so I don’t know for sure, but it’s my best guess, at least.
Don’t know what you are doing about maintenance. The fronds that are hanging downward can be removed at this point and that might help with some of the shading issue. I’m guessing the palm helps shade the window near it.
BTW some palms are self cleaning and will drop their fronds and boots.
I didn’t even know that self cleaning was a term that would describe palms, but these do appear to be self cleaning. If I leave the fronds and such (as I tend to do) they will eventually drop off. As I said above, occasionally I have tried to trim off some of the fronds that are on their way out, but it’s not an easy job and honestly it doesn’t seem to last very long. Within a month or two it’s just got more.
If your palm is a queen they are pretty prolific with seeds
Yes, yes they are. I have that one and another one on the other side of the house (which is a bit further from the house and not near any panels) but they both drop a lot of fruits several times a year.
@BrettS another question for you is will the production loss on a panel or two for part of the afternoon make a huge difference in your house usage? Suppose that depends on heat and A/C usage at that time of year and whether you are feeding back into the grid and at what price and over how many hours.
My solar system is pretty big, but given that all my appliances are electric and that I have a car to charge I still only expect it to meet 70 or 80% of my annual power demand, so any extra power I can get would be used.
Or, move it far enough that shadow misses house?
Unfortunately I think moving a tree of that size would be cost prohibitive. Additionally I have a septic system with the drain field in the front yard and I was given no map or anything to show exactly where the drain field is, so I would be a bit concerned about the large trucks driving over the yard to move the tree (not to mention trying to find a place to put it)
Glad to take the palm tree though. Would give a beachy feel and contrast nicely with the snow for the short amount of time it would survive.
You can have it. All you need to do is come down here and pick it up
