What's my range?
So, what would you conclude is the fully charged range of the car?
  • 257 miles (Based on using 31.6kWh to go 108.4 miles)
    Votes: 0 0.0%
  • 217 miles (Based on 50% remaining battery gauge after 108.4 miles)
    Votes: 1 16.7%
  • You're thinking about this too long.
    Votes: 5 83.3%
  • Total voters
    6
I've been a bit concerned over what appears to be a significant loss of range in the last few months. I knew I'd be going on a longer than normal drive this past weekend so decided to run a test. I charged to 100% for this first time in a long time and took off. Normal highway driving (70-75mph) for almost the entire journey.
As you can see in the attached photos, here are the stats:
From the IC:
108.4 miles
31.6 kWh used (291 Wh/mi)
Battery gauge shows 50% remaining
The Energy app shows a projected 127 miles remaining, based on the last 30 miles at 278 Wh/mi.
What was the rated available range in miles at 100%? That’s really the best and only tool you have to gauge any degradation without a scanner and/or access to the BMS.
You’re not likely to ever arrive at a satisfactory conclusion trying to make sense of the consumption in the energy meter.
Reactions: Rocky_H
It was ~220 in the Energy app, but that's based on the previous 30 miles with ~330 Wh/mi usage.
Andrew, my range has dropped a lot in last year. There r several post above on this. I got to DC often, i use a lot more range now. I got a new motor in February. I dont know whether its battery or more powerful motor. I go to JAX once a week. It takes 10 more miles of range now for this trip. I blame the SW updates. There r a lot of complaints in post above. Here is my battery report today.
Is that report from TeslaFi?
