NigelM
Recovering Member
no. if anything it's worth less since the earliest cars have the most issues.
Nonsense.
I can't imagine that "Signature" has any added resale value at all. I have driven two 2013 VINs, no0t even sigs, as loaners and mine is much better built, quieter, smoother and everything else. I tell my friends to not consider anything before 2014 because it seems they worked the kinks out by then.
FWIW, my March 2013 car with 60,000 miles seems just as well built as any new loaner I've had, and it certainly has not developed any new noises, rattles etc. over that time.
Do you have a source for that? I can't find it now but recall some owners doing side-by-side tests and the results being closer to 5 minutes due to the way the pack charges and tapers as it gets full. I think there was a bigger difference between 60 kWk packs and 85's (and presumably the newer 70's) with the 85's of any generation being faster.
Not so on the 60 vs any gen of 85 part. My very early 60 could supercharge at upto 105 kW while the A-pack 85s capped off at 90 kW.
Yes, but the 60s charge slower overall than the 85s (or at least so I thought) due to the smaller pack size. Bjorn did some side-by-side comparison videos and this was my recollection.
FWIW, my March 2013 car with 60,000 miles seems just as well built as any new loaner I've had, and it certainly has not developed any new noises, rattles etc. over that time..
KBB disagrees. If you follow these two pages and align the configurations, the default mileage of 15631, and pick Very Good condition you get the following...
$74,248
Kelley Blue Book
$69,431
Kelley Blue Book
FYI
IndeedSignature Red paint color does add value and/or resale speed. For collectors, the Signature branding would add value.
It might be 5 minutes. However, I was provided with a version "B" 85 kW battery pack when my 85 kW "A" pack was sent to Fremont for the battery switch upgrade. The 6 weeks that I had the "B" pack allowed me to drive from SoCal to OKC and enjoy the faster Supercharger speed. My "A" pack has shown 290 MPH of range flow maximum while the "B" pack showed a maximum of 380 MPH. Granted, that is occurring only when the battery has about 30 to 50 miles left, but even as the taper occurs, the version "B" pack would show higher numbers. The reason for the faster battery charging is due to the cooling system in the pack. Increased cooling allows for the higher rate, just as the new liquid cooled Supercharger cable can be of a higher amperage.Do you have a source for that? I can't find it now but recall some owners doing side-by-side tests and the results being closer to 5 minutes due to the way the pack charges and tapers as it gets full. I think there was a bigger difference between 60 kWk packs and 85's (and presumably the newer 70's) with the 85's of any generation being faster.
One other thing... The version "A" battery has been through many Supercharger adventures through the Pacific Northwest. One drive required a lengthy range charge. The time it took from 90% to 100% was about 45 minutes to an hour, since the heat generated at those levels is so high. It did not take that long with the version "B" pack on the OKC trip to avoid a stop in Amarillo.
So I have a 2012 Signature that I picked up as a CPO car. By the time I got it, all of the bugs were apparently dealt with since it has had no significant issues in the 24 months I have had it. It is serial number 00233...a very early car. Had one door handle replaced, that's it. Car has 40K miles on it now and runs like a dream. I have had a couple of loaners and except for the one that had Auto Pilot I have not noticed any significant quality upgrades that distinguish them from my "old" MS.
