So I've had my MY LR AWD for about 3.5 months now and started logging data with TeslaMate about 2 months ago. I street park most of the week in NYC and drive the car on weekends. When the car is parked, I leave sentry mode on. I do not use cabin overheat protection.
I couldn't help but notice when looking at the vampire drain report on TeslaMate, that there's an interesting fluctuation in the internal cabin temperature. If you look at the attached graphs, you can see this yellow line almost shadows a few degrees above the outside temperature but has a sawtooth pattern. The pattern seems the same regardless of whether it's at 48F - low 70s. There's a very obvious spike when the outside temps are over 75F.
At first I theorized that the heat pump was moving warmer cabin temperature to the battery when it's colder, but I didn't think this would happen at temperatures as moderate as the mid 60s-low 40s. Also it doesn't seem to try "harder" the lower the temperatures go.
Curious to hear your thoughts, theories or knowledge regarding this data...
