Just for redundancy I'd like to install a Dash Cam and I'm trying to figure out the best way to do it.
I'd like the install to be as clean as possible from the inside and the outside and this is the best mount I could find:
BlackVue mounting bracket for Tesla
It basically makes the DashCam a part of the rear view assembly and most people will never even realize there is a Dash Cam installed even when they are inside the car. Has anyone found a better solution for mounting a Dash Cam in a Model S? I feel the 115 Euro price is a bit high though.
Apart from the mount, what's the cleanest way to tap into power in the microphone area so you are not splicing cables? isn't there some kind of a connector that you can use with always on 12V power? Can I solder a corresponding connector to the Dash Cam wire so that it can cleanly plug into the existing connector? Should I fuse this connection to the Dash Cam?
