What's the max generation you've seen for a 16.2kWh system at any given time?
bkp_duke
4,959
15,687
San Diego, CA
Hey all. For those near me in SoCal can you give me a reading on your peak output today thus far? I’m trying to get a gauge on if my output is up to par yet because Tesla techs came out yesterday and rewires some of my panels that were reverse polarity.
I’m getting 8kW right now and it’s my peak output.
Peak about 8 kw on a 12 kw system
Reactions: njhtran
bkp_duke
4,959
15,687
San Diego, CA
Thanks. My system is 16.32kW. I wonder if that means something is still wrong.
I’m getting a lot of smoke overcast though. Since youre closer to the coast is it less ash and smoke overcast for you ?
Just an observation, but I've seen that my 12 kw SunPower system out-performs the equivalent Tesla system (by a lot).
Wait till you have a clear, cool, sunny day and measure your output before you jump to any conclusions.
Also, I'm a good bit south of you, closer to the coast, and on a mountain, so my ambient sunlight right now is probably different from yours.
Reactions: njhtran
SoCal Dave
408
309
That is looking better. I had 7.1 kW for my max today on my 12.24kW
Reactions: njhtran
BrettS
2,108
2,511
Orlando, FL
That’s great news. It’s encouraging that they were able to find a problem and correct it. Hopefully over the next few days or weeks you’ll be able to see your output closer to what you were expecting.
Reactions: njhtran
JeremyWhaling
88
74
So. Cal.
Peaked out at 2 kW on a 4 kW system today. Looking at about 13 kWh for the day. Best days a week ago were 3.1 kW peak and about 22 kWh. Near coast, AQI is 140 right now. Amazed I'm producing at all right now (~400 W) with the sun being so dim and red...
Reactions: njhtran
njhtran
354
125
Temecula
For the past few days the sky has been clear and I’ve only generated in average 55kWh The highest being 60kWh. The max generation at any point in time is 9.2kW (system rated for 16.3kW). If every day the entire year produces as much (sunlight from 6am until 7pm) then I would only generate 18mWh yearly. The system design was estimated @ 24mWh based on my needed consumption.
the 18mWh is BEST case scenario and yet falls short by a wide margin. I’m cringing at the idea of starting another ticket and having to convince them of the issue. Wish me luck
BrettS
2,108
2,511
Orlando, FL
You need to be careful about trying to figure out annual production based on only a few days because different days can vary widely. It’s better to look at production over several weeks or several months.
But that said, it really does sound like your system is underproducing. I think it might be beneficial for you to request access to the solaredge portal from Tesla and then connect your inverter(s) to Ethernet so data can be reported to solaredge.
On the solaredge portal you will be able to see per panel data, so you can make sure that your system really is seeing all your panels and see if some panels are producing considerably less than others.
darhall993
112
95
Sandy Springs, GA
+1 on BrettS suggestion to get access to SolarEdge portal. I have SolarEdge and Powerwall's and having the data on each panel and Inverter status has been hugely beneficial. You will want to see all the details on which panels are producing and how much. Even if you don't use it all of the time you can use it as a reference. I have my SolarEdge connected via Ethernet and use it daily. There is also a Mobile app which is handy as well.
darhall993
112
95
Sandy Springs, GA
Here is an example of the SolarEdge portal during and outage/troubleshooting event earlier this year, I had water in one of the junction boxes which created some issues. Also had some issues with configuration of the inverter, I admin I'm a telemetry and performance geek but this interesting and helpful on many levels.
SoCal Dave
408
309
For a point of comparison, below is the output from my 12.24kW system. My production has been falling off since I had a peak of 67.1kWh back in August. The smoke haze, heat and days getting shorter I think are contributing to it.
Reactions: njhtran
jjrandorin
Nov 28, 2018
7,197
7,980
Riverside Co. CA
Your 16 kWh system produced almost exactly double what my 8.7 system produced yesterday, and we live in the same city. I believe this was said in the thread somewhere, but the "max generation number at one time" is not an appropriate thing to measure.
Your system is about twice the size of mine, and generated about twice as much energy, in the same city. I have had my system since 2015 and know what it produces. Based on your 55-60 kWh generation number, it looks correct to me based on my own generation for my own known working system thats 8.7 kWh also in temecula.
SoCal Dave
408
309
We need to have a Temecula Solar Meetup where we can just stare at each others solar arrays ;)
jjrandorin
Nov 28, 2018
7,197
7,980
Riverside Co. CA
@njhtran / @SoCal Dave
Lets compare production today, 09/21/2020. When my solar stops producing for the day,I will post what my production is. Since we are in the same city, with different size PV setups, maybe that will help @njhtran see if the production looks "normal" or not.
I know we are likely in different parts of the city, with different roofs, etc... but temecula isnt THAT large of a city so this might help. My production has been creeping UP a little, which is unusual this time of year since it normally goes down a little each day at this point in the year.
Reactions: njhtran
SoCal Dave
408
309
Sure.
You can see in my graph it has been trending up slightly since the really bad days. A bit cooler and less smoke haze I think are helping a bit right now.
Production as of 3 PM is just a hair less than yesterday. But I'll post my final numbers when production ends at 6:30 for me.
Reactions: jjrandorin
jjrandorin
Nov 28, 2018
7,197
7,980
Riverside Co. CA
Sure.
Ok..
Date =9/21
System Size = 8.7kW
Highest peak generation shown =5.1kW
Solar generated today =35.4 kWh
Location - North Temecula (Temecula / Murrieta Border area)
