From the new HPWC manual I see "Daisy Chaining Multiple Wall Connectors"
Set one Wall Connector as the master by
setting the Rotary Switch Position from 1
to 8 depending on the maximum available
output current. Set up to 3 Wall
Connectors as slaves by setting the Rotary
Switch Positions to F. In the load sharing
network, only one unit can be designated
as the master (refer to Set the Operating
Current on page 21).
My 200A service panel has plenty of load capacity, so it seems I can use a 100A circuit to daisy chain 2 HPWC's I have on hand to install. However, the manual seems to say the Max charge setting in this instance is Setting # 8 = 40A. Is this just a typo? What good is daisy chaining if it just splits the 100A circuit in this case and limits my charge even when only one is in use.
