What's with the rear seatbelts?
Discussion in 'Model S: Interior & Exterior' started by gg_got_a_tesla, Jul 15, 2012.
  1. gg_got_a_tesla
    gg_got_a_tesla Model S: VIN 65513, Model 3: VIN 1913
    Redwood Shores, CA
  2. NigelM
    NigelM Recovering Member
    Northern Virginia
    Both in the same car, pearl white Perf.
    I have had it MB cars that the belts could "lock" if you pulled them too sharply...wonder if these are just MB components that people are not used to?
  3. doug
    doug Administrator / Head Moderator
    SF Bay Area
    If it's the same car, it probably just needs an adjustment.
  4. donauker
    donauker Member
    Silver performance had a problem with the right rear seatbelt as well. You could feel it binding a bit as you pulled it out and it wouldn't retract without feeding it back though the slot. Seemed like it needed more clearance or some obstruction was interfering with it's movement.
  5. dflye
    dflye S Sig Perf 414, VIN 814
    Raleigh, NC
    The belt I had issue with was in the silver performance in DC.
    It went into the lock mode used for securing a child booster seat, but pretty sure I didn't pull out enough belt to trigger that in the normal fashion (where you get all the way to the end of the belt before it kicks in). Had to unbuckle and rebuckle to get it to operate like normal. I don't recall the texture of the front belt, was too busy enjoying the driving then (and not being pinned in place like the back seat :tongue:)
    Although forgot to mention in the review, the inside trim just below the driver seat belt feeder was popped off the frame by about half an inch, not sure if they were working on the belts, or if a gorilla was in the car on an earlier test drive. :wink: Didn't get a picture of it, and looking at the ride video, the popped panel is partially seen at the edge of the video around the 5:15 mark.
  6. Bardlebee
    Bardlebee Member
    San Antonio, TX
    Here is the silver lining. It seems they got this car right in all the right places and all that is wrong with it are very minor adjustments. I take it as a good sign. :)
  7. AnOutsider
    AnOutsider S532 # XS27
    I wonder if it has anything to do with the auto tightening that happens when you start a Mercedes
  8. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    No issues with the right rear seat belt in the gray performance at the Seattle event.
  9. NigelM
    Northern Virginia
    Sorry, I missed that you had been in 2 cars. I read that you had driven the white and didn't register that you rode again in the silver. My bad.
  10. Discoducky
    Discoducky Happy owner of a P100D X and a brand new 2021 M3!
    Seattle
    same here other than the shoulder height as it would go down my arm when id lean forward
  11. gg_got_a_tesla
    Redwood Shores, CA
    Tried these out today in the silver non-perf car at the Palo Alto event. Didn't have any issues with the rear seat belts except that it was a little difficult to buckle in into the slots that are fixed rather than 'hanging out' as they do in most cars that I've seen.
  12. kendallpb
    kendallpb Model S: P 8061
    MD, USA
    I mentioned this re. the green non-perf. in DC in my review, too. On the other paw, as someone pointed out, I've hit this in other cars. I'm not sure if it's related to odd braking maneuvers or what, but in my other half's Nissan SUV, I've had this kind of experience and it drives me batty...keep removing/replacing seat belt, want to rip the damned thing out.
    Of course with regen, it couldn't be a braking problem.... ;-) So I dunno. But it's not just one car. On the other paw, a woman from Tesla, when I mentioned it, said she'd experienced the opposite (seatbelt too loose!), so this may just be early production jitters that'll get polished as the real sales roll off the line. She was very quick to reassure me they'd iron this out, anyway. ;-)
  13. CapitalistOppressor
    CapitalistOppressor Active Member
    I mentioned that in another post, so maybe it was me you saw. One of the trouble reports said the lady pulled the belt out and it got stuck for several minutes before she got it to work. I had EXACTLY the same problem a few weeks ago in the back seat of a 2011 BMW 538i. Belt got locked halfway out and I couldn't get it unstuck for several miles (about 4 or 5 minutes at a guess). Frankly, I have difficulty thinking of any car I've ever been in where there wasn't some problem with the belts getting locked or stuck or hung at some point.
    Maybe the only exception I've ever seen in a car was a 1990ish Ford Tempo that I drove in college. It had powered seat belts for your chest and a manual belt for your lap which I don't ever recall hanging or having trouble with. Every other car I've ever owned, the belts get stuck occasionally. And in trying to think back on my life experiences, I think its fair to say that I have the most trouble using seat belts when I am a passenger in an unfamiliar vehicle.
    It makes for a pretty straightforward hypothesis to say that when using an inherently finicky device like a seat belt you are most likely to have a problem the first time you use it. That using a particular seat belt is a learned skill. How quickly you pull it, what angle and force you use, and the timing with which you apply those forces, all matter in whether the mechanism works or not. And that literally every seat belt in every car is different, and differences are far more pronounced between (for example) the front drivers side seat belt on a BMW M3 and the right rear seat belt on a Tesla Model S. And that in the end, regardless of whether you "do it right" a seat belt is finicky because it has to be biased towards locking up to save your life in a crash, vs being easy to pull out and retract on command.
    So it's simple statistics that some people taking test drives will have a problem with the belts. Thousands of people have already had reason to belt themselves in, and my guess is that in an unfamiliar car (where you haven't had an opportunity to adjust yourself to the particular belt mechanism in that car) and in an unfamiliar seating position (like a back seat) the number of failed attempts would be higher than you would see in regular use. Given the number of people who have ridden in the cars so far it should be anything but shocking that there were problems, and once one report was made a lot of people would chime in to say they also experienced problems.
    None of that speaks to the quality (or lack thereof) of the belt fabric which was also reported as a problem. An issue like that is still subject to opinion, but its a much more straight forward problem. If people think the fabric looks or feels cheap that's certainly something I'd like to know (and see pictures of) until I have an opportunity to check it for myself.
    P.S. - In an aside, it should be noted that every belt in every test car has been used hundreds of times in the past few weeks, which is probably equivalent to a year or three of anticipated use for front belts and a lot more than that for the rear belt mechanisms. Even folks with kids don't use rear seats as much as front seats, and children place far less of a load on a mechanism than an adult does. Hundreds of adult/buckle-ups over the course of a few weeks might not be something the engineers designed for (anyone know whether Taxi's use a heavy duty/non-stock mechanism for the rear seat belts?).
    In a very related note, its very easy to forget that while the vehicles being used for test drives are just a month old, they are being intensively used in a way that is far from typical. They are already much, much more than a month old in terms of use, and certain components may be being stressed in ways not typical of normal use.
