What's with the snowflake?
Discussion in 'Model S' started by whitecotton, Dec 16, 2016.
Tags:
  1. whitecotton
    whitecotton Member
    Houston, Texas
    Being from Houston it is highly unlikely that I see it in person, I saw on the Facebook page many different answers, does anyone know for sure the answer?
    Also looking for clarification on another issue- does range mode heat the battery?
  2. jdw
    jdw Supporting Member
    Montreal, Canada
    The snowflake means that the battery is very cold and power and capacity will be limited.
    First stage of cold: Limited or no regen available
    Second Stage of cold: Available power is slightly reduced
    Third stage of cold: The snowflake appears and power is seriously limited and no regen available
    It hit -22 here yesterday and after the car sat in that all day, I’ve never driven a Tesla that gutless. I had zero regen and only about 50kW of drive power. I could barely get up to highway speed ...
    • Informative x 9
  3. beegee
    beegee Member
    Wentzville, MO
    It was added as part of a software upgrade. When the battery is cold the Snowflake is coupled with a blue section of battery (at least it was), and that amount of energy will be used to warm the pack up to the operating temperature. I've only seen it once after parking all day on a cold day.
  4. odguy
    odguy Member
    Wisconsin
    Curious did you pre heat the car at all?
  5. green1
    green1 Active Member
    Calgary, Alberta, Canada
    I had a very similar situation this past weekend, parked outdoors and unplugged below -20c all day. I pre-heated the cabin for 20 mins before going out to it, and had no "snowflake" (in fact I've never seen it) and although my power and regen were both limited, the road itself was far more limiting and I had no desire to get anywhere near the power limit. (the power limit went away very quickly while driving, the regen limit, as usual, stuck around for quite a while)
  6. whitecotton
    whitecotton Member
    Houston, Texas
    so to clarify the snowflake replaced the blue portion of the battery indication?
  7. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I remember those days. Thank the lord I moved to CA and became a total "weather wimp":)
  8. whitecotton
    whitecotton Member
    Houston, Texas
    It is forecasted to be a low of 28 Sunday night... I'm about to lose my mind hahah I need to take a last minute trip to a warm beach.
  9. NikeWings
    NikeWings Active Member
    Los Angeles
    +1
    Boston is in my rear view mirror. :cool:
  10. jdw
    Montreal, Canada
    No, I had Range mode on, and the car wasn’t plugged in so I just got in went. I did turn range mode off fairly soon after and the power limitation began to gradually improve.
  11. kort677
    kort677 Banned
    florida.
    If I am not mistaken preheating is for the cabin, the best advice for when temps are that low is to keep the car plugged in, even a 110 will keep the battery warm and protect it from those harsh conditions.
  12. darker123
    darker123 Member
    Jersey City. NJ
    Can someone post a picture I assume it is shown on dashboard...
    • Helpful x 2
  13. jdw
    Montreal, Canada
    Don’t have a picture, but it is now a small blue snowflake to the left of the charge indicator in the lower left corner of the intstrument display.
    Plus, with range mode on, preheating only preheats the cabin. With range mode off, preheating heats both the battery and the cabin. Very obvious in the power consumption - with range mode off the car draws 2-3 times the power compared to range mode at extremely low temperatures.
  14. CHG-ON
    You betcha! Lovely dog, BTW.
  15. CHG-ON
    We are actually in the low 30's and can hit mid-low 20's overnight in Santa Cruz occasionally. The hippies simply don't know what to do with that!
  16. johnster007
    johnster007 Member
    Minneapolis, MN
    Here are some pics. It's cold up here!!!
    • Informative x 2
  17. drklain
    drklain Member
    Scottsdale, AZ/Fairfax, VA/Brussels, BE
    -1F! Now I remember why I don't want to live in Minnesota... ;)
  18. RDoc
    RDoc S85D
    Boston North Shore
    I saw the snowflake when the car was cold soaked overnight at about 18F. The Wh per mile number was terrifying, over 430!
  19. mknox
    mknox Well-Known Member
    Toronto, ON
    Never seen it once in my car ever (now in my 5th winter) even cold soaked as low as 0 F. Asked Tesla Service why and they had no explanation. Have seen it in loaners I've had.
  20. Peter Greis
    Peter Greis Member
    Stäfa, Switzerland
    Saw the famed blue snowflake two weeks ago during the Telemark festival here. -22°C, left for Davos with 49km range left. 8km later in Davos I had 9km left when plugging in.... too close for comfort.
