How do you tell what battery pack you have (A, B, etc.)?
I have a Dec 2014 P85D on .536. 90% SOC rated miles insane mode range mode off is 224. Lifetime watts/mile is around 350.
Is there any consensus on whether there's a tradeoff between what charging behavior yields "best range" and what yields "optimal battery lifespan"?Always charging to 90% or higher typically yields the best range.
Nobody but Tesla knows for sure. All we know is that 20-50% charge is the best for the battery, but if the car isn't charged to 90% regularly, the battery gets out of balance. It's possible to get it back into balance with either many consecutive range charges, or just charging to 100% for a while(both are bad). Hot rodding the car with a low state of charge is also bad, so if you step on it all of the time, it's better to charge to 90%.Is there any consensus on whether there's a tradeoff between what charging behavior yields "best range" and what yields "optimal battery lifespan"?
Elsewhere on the forums, I've read that keeping the battery between 20% and 80% is best for lifespan, and some have even said keeping SOC at 50% is ideal. But would that also be expected to result in decreasing range, or is this simply a matter of losing calibration when charge cycle deltas are relatively small?
My 90% has gone from 239 to 233 rated miles over the span of a year. This might be because I've been charging only to 80% most of the time, and I never go below 20%. Does the battery periodically need to be exercised over its full range to report accurate stats, and is it a good idea to do so? Haven't really seen an answer to this yet.
All we know is that 20-50% charge is the best for the battery...
2013 delivered in May of that year S85.
221 rated / 256 ideal at 90 %. Have 20,000 miles and a lifetime 373 kWh / mile.
Sounds low. They have revamped the software so many times I really do not know what to think. I rarely charge to 90. Usually charge to 70 or 80. Have supercharged six times. Perhaps because I park and charge on my driveway (no room in garage, of course)?
My 90%?! About four beers....
40s or cans? and is that including pouring one out for all the gas stations that aren't getting money from you?
It's interesting that your 90% is substantially above average (and above the standard "new" value of 235), but your 100% isn't.60,000 miles on the car, 41,000 on this battery that I know of (mine was a refurb replacement pack due to the contactor issues, before the service centers could fix them). My 90% charge is 238 miles, range charge is 264 miles (240/266 when installed). I always charge at 80A when at home, and supercharge without concern (although I don't have a "local" supercharger).
