What's your total average wh/mile
Discussion in 'The UK and Ireland' started by Subevo, Jul 22, 2018.
  1. Subevo
    Subevo Member
    Scotland
    mines is 365wh/mile in 4500 miles in a model s 75D
  2. suwaneedad
    suwaneedad Member
    Atlanta
    262wh/mi, 7k mi, Model 3LR
  3. WARP 10
    WARP 10 Member
    San Diego
    300wh/mi. After 28000mi. S 75
  4. Penfold
    Penfold Member
    Surrey
    340Wh/mi after 11,412mi for S 75D
  5. evp
    evp Nerd
    Arvada, CO
    320Wh/mi in a 2014 S85; 107K miles.
  6. arg
    arg Supporting Member
    Cambridge, UK
    Note that this is in the UK forum, so I’m guessing the OP wanted answers reflecting UK weather and road conditions.
    I’m away from home at present so can’t get the precise number off my car, but it’s in the region of 340 (S85 after 4 years). I’ll try to follow up when I get back.
  7. DJP31
    DJP31 Active Member
    UK
    333 Wh/m 22k miles S75D
  8. WannabeOwner
    WannabeOwner Active Member
    Suffolk, UK
    This for UK journeys:
    Split mine per-month, and also showing journeys / miles. Commute is 40 miles each way, so most journeys are "not short" and correspondingly power hungry, e.g. in Winter. Also shown some representative wH/mile for longer trips taken within that month (usually cruise control at a constant speed [for journey, but might have hit roadworks / traffic for part] and AP = ON). They will mostly be "range conscious" and Range-mode = ON journeys, but also on occasions when home was within easy reach whoever was driving :rolleyes: may have sped up; should be representative for "what is achievable on a longer run in that month".
    Couple of months had insufficient data to be reliable (car at Tesla for several weeks :( or off soaking up some sun :))
    MonthDrivesMileswH/miTrip examples >80 miles
    July451100368340
    June561500354340
    May672600369310,330,360
    April612000400380,340,360
    March712100424390,446(85)
    February301000457435,476
    January501800424410,460(85)
    December0
    November471000390320,360,one day: 20 Drives 36.43 Miles 459 Wh/Mi
    October351100360320,350,360(80)
    September0
    August0
    July601800350340,380(80),370,300(70)
    June531600355330,350(75),370(80)
    May702400374350,330
    April341100402380
    March291000390350,324
    February27400447438,380
    January721900429380,370,400,420(73)
    December511100418380,430,360
    November953300389360,400,340
    October962600372350,360,430(90)
    September1032900348340,350
    August761800333330,360
    July32800365360
    • Informative x 2
  9. dog_car
    dog_car Member
    293 Wh/m, 22k, S90D, Calif
  10. Subevo
    Subevo Member
    Scotland
    Thanks for he posts so far. I do like to floor it on a regular basis for short stretches to remind me of the grunt the car has. so not too bad at 365wh/mile.
  11. Tevvy
    Tevvy Member
    UK
    I got mine in Sept last year and up until April was getting 384. However since May this has now reduced to 347. I reckon if I'd have zero'd it in May, I'd be close to the magical 300 now. The heat (or rather lack of < 9 degrees) makes a huge difference.
  12. Terry_B58
    Terry_B58 Member
    Lancashire. UK
    312 Wh/mile - 10700 miles since the end of March :D:D:D
  13. Fellsteruk
    Fellsteruk Member
    North West, UK
    Help me.
    What is this? Is it basically like the EV version of MPG? I’m trying to train my lead foot now to help my range
    Forgive me not got my MX yet.
  14. Tevvy
    Tevvy Member
    UK
    Yes it’s the equivalent. I’m on an electric tariff which charges me 6p per KWh. A KWh is a 1,000 Watts/hr (like having ten 100w lightbulbs on for 1 hour) .
    So if you’re averaging 333 KWh in the car it’s like 1/3rd of a KWh, so in essence that mile has cost 2p to do.
    It’s complicated but when you get your head around it, it’s not too bad.
    My equivalent mpg is around 300 mpg!
  15. WannabeOwner
    Suffolk, UK
    #15 WannabeOwner, Jul 26, 2018
    Yup. Probably worthy of an explanation.
    Petrol : Miles per Gallon.
    EV : wH/mile - so if your car has a 75kWh [available/usable] battery and uses 333 wH/mile - i.e. 3 miles per kWh - then your range is 225 miles
    (MX 75D is, I think, actually 72.6kWh useable and 324 wH/mile)
    If you drive slowly you might get, say, 275 wH/mile (3.6 miles / kWh +20%), and in bad/cold weather you might use 450 wH/mile (2.2 miles / kWh -27%), in practice in cold winter weather (OR torrential rain) allow +20%
    The main relevance is that the "fuel tank" is smaller than an ICE (along with slower to re-fuel, and fuelling station "not on every street corner"). However, with EV you can start every day with a full tank of fuel
    To calculate range assume?? that you need 20 miles "comfort", and that you will normally only charge to 90%
    Using A Better Route Planner to plan a trip from Suffolk to Edinburgh assuming max speed 80 MPH and Temperature 60F/16C I got:
    MX 75D range at 100% charge is 153 miles
    20 miles comfort, and 90% charge = daily range = 118 miles
    Winter max range 115 miles, daily 89 miles
    I doubt that matters, provide that you don't use the brakes (i.e. only use Re-gen). Somewhat faster acceleration, without also using brakes, is probably not that much more energy used.
    EDIT: Mucked up some figures above, now corrected.
    Same journey at 70 MPH, with 100% reference speed (instead of 110%):
    MX 75D range at 100% charge is 169 miles
    20 miles comfort, and 90% charge = daily range = 132 miles
    Winter max range 127 miles, daily 99 miles
    In practice you will do better than that because of Traffic / Roadworks enforcing 50 MPH for some part of motorway journeys.
  16. Fellsteruk
    Fellsteruk Member
    North West, UK
    Thanks for the detailed reply, makes more sense and hopefully once I get the car and start driving her I’ll get use to this :)
  17. Scooter
    Scooter Member
    NYC
    MX 75D for 13 months in the Northeast and about 12,000 miles. I have an average of 332 KWh. A recent road trip brought down the average consumption as I was usually part of a car train on a 2 lane highway. The winter season was abyssmal as it regularly averaged 400+KWh.
  18. arg
    Cambridge, UK
    Mine is 336 Wh/mile in an S85 after a shade over 4 years in UK conditions (so even mix of summer and winter).
    This is mostly on longer trips (no commutes, but occasional local errands).
    If thinking about range, it's only the longer trips that matter - if you are not going far it doesn't matter what Wh/mile you get as you won't run out.
    Conversely, if thinking about running costs none of these figures gives an accurate answer, as they come from the on-board instrumentation recording energy out of the battery; energy taken from the mains to recharge will be at least 10% more.
  19. culverwood
    culverwood Member
    Herts
    349 Wh/Mile over 16 months
  20. Peteski
    Peteski Active Member
    UK, Milton Keynes
    This shows me how much variability there is depending on personal usage. My MX 75D (2018 uncorked) has averaged 438 Wh/mile over the last 8K miles from new. I took delivery in mid Feb, so that includes a mix of winter, spring and summer usage. On a long trip I can get down under 350 Wh/mile, but most of my shorter trips are 400+ Wh/mile. Maybe yours is a corked car, which would explain some of the huge difference. But I expect it's mainly down to different driving style and journey types. I do a lot of short fast trips cross country in little or no traffic.
