Wheel alignment (lowering question)
zanardi43
22
15
Upstate NY
I've been on the fence about getting lowering links installed on my MX P90D, but my major concern (other than potential air suspension issues) is having enough latitude in the wheel alignment range to be able to accommodate a lowered stance. If anyone has lowered their MX and/or has first-hand knowledge of the MX alignment range capabilities, I'd be most appreciative.
Reactions: Cowby
SMSMD
1,352
629
Edmonton, Alberta, Canada
Go to controls. .suspension. .you can set your Tesla from Very high to very low. .it's remembered on your GPS location and automatically goes to that settings. There is a speed limit that you can set it to go low which you can use it for highways.
I use high when I go to malls to avoid the curb during parking & speedbumps.
vandacca
ReActive Member
Oct 13, 2014
3,371
2,202
Hamilton
Note: Only High and Very High height settings are remembered at a particular GPS location. Right now, you can't have the Model-X remember low or very low at a GPS location (which is a shame). I'd like to set my Model-X to go into low everytime I park it in my garage so that the FWD will clear the garage door motor.
Reactions: Cowby
zanardi43
22
15
Upstate NY
I should have been more clear...I am aware of (and use) the adjustable air suspension currently. What is like though is to have an even lower setting than the OEM 'very low'. I can buy lowering links to accomplish this, but want to understand how much alignment room/tolerance is available first.
Thanks for the replies.
SMSMD
1,352
629
I should have been more clear...I am aware of (and use) the adjustable air suspension currently. What is like though is to have an even lower setting than the OEM 'very low'. I can buy lowering links to accomplish this, but want to understand how much alignment room/tolerance is available first. Thanks for the replies.
There are some posts on TMC about unequal tire wear when constantly run on Very Low settings...I don't have personal experience with that, just quoting.
