  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Wheel-nut torque
As a matter of curiosity, can anyone tell me why the wheel-nut torque on the MS is so high - 129 lb ft (175Nm)? Cars I have dealt with over the years have all required about 70 - 80 lb ft. My wrench does go high enough but I don't know whether I could push it that far (or, more to the point, undo the nuts); good thing one will not have to do it at the roadside! I wonder whether most tyre shops do them up tight enough - they seem to have their guns at a single setting that they use all the time.
Johan
Ex got M3 in the divorce, waiting for EU Model Y!
Feb 9, 2012
7,509
10,013
Drammen, Norway
It likely has to do with the agressiv torque available from a standstill and the weight of the vehicle.
175 Nm is more than most cars, but you won't have trouble undoing a 175 Nm lug nut manually, I can guarantee that. If you have a wrench that extends 35 cm from the nut (normal tire wrench) you'd need to apply the equivalent force of 50 kg - not too hard for most people. If you have a slightly longer wrench the force needed will of course be smaller.
jerry33
20,662
28,498
Texas
The Corvette has a similar torque, so it's not uncommon for very high performance cars. After 100 miles or so of driving the wheels should be re-torqued, so that would take care of any problems.
Note that it is easy to remove the nuts with a breaker bar, requires almost no force.
