Moving the offset to counter additional overall width when done correctly merely adds width to the outside without removing it from the inside.
Interesting that you think sunken wheels provide an aerodynamic advantage. Why then when manufacturers add wheel well covers do they make them flush with the body panels? Why do trucks place the trailer as close to the cab as possible to decrease the gap and thus less drag?
This moves the centerline of the wheel out further from where the steering geometry wants it to be located.
You're putting more meat down on the road on the outside steering edge and less on the inside.
explain why after 12,000 miles with factory alignment my tires are not showing accelerated wear on the inside edge.
If pressure was being exerted off centerline then more wear would be shown on that side.
In my opinion, there is no such thing as a properly installed and torqued spacer. You have two surfaces instead of one, which causes looseness after a bit of vibration. In addition, you've changed the centerline of the tire from the OE setting which puts additional stress on the suspension and wheel bearings. I've seen too many vehicles that rolled over because spacers were used. A Tesla is most immune to rollovers, but not to other damage. Scottm is spot on.Bought a set of 19mm spacers to fit in May 2018. Spacers where installed and torqued properly mid Jun 2018.
thanks for the update and the photos. I have 20 mm spacers and will have to take the wheels off to check for any similar markings.
Hi Fellow Model S owners,
Ive been a member of this forum for almost a year now but mostly a reader and haven't contributed nor posted any thread before.
Today i feel that i need to post this for all owners running spacers on their model S, 21” rims in particular as this is what i have.
I own a 2013 P85 running 21” wheel non-staggered. Bought a set of 19mm spacers to fit in May 2018. Spacers where installed and torqued properly mid Jun 2018.
View attachment 334918 View attachment 334919
Today early morning ive noticed a weird noise, metalic scrapping, from the rear left wheel so i pulled over and inspected the car but found nothing to report. On my second drive i noticed the sound had become more pronounced, so again i pulled over and tried to shake the wheel and thats when a lug nut fall on the ground. Lucky enough i was less than 10 minutes away from a tire shop, took off both rear wheels to find out that the spacer studs are snapped
View attachment 334895 View attachment 334896
As you can clearly see the rear left spacer has one stud broken and resting within the lug nut. Right side had 3 studs broken as we removed the lug nuts.
Now this is my daily car that i drive atleast 150-200km a day with my family inside. I cant imaging what wouldve happened if i lost more studs and wheel came off. I am glade that i noticed it early enough to prevent and harmful damage.
I have sent the manufacturer an email, and i will not disclose their name yet as i will give them the chance to justify/explain the reason for such issue to happen. But the main purpose of this thread is for all owners with spacers to check their setup thoroughly and periodically as this is extremely dangerous.
