Wheel Spacers Fitment for Model X with factory 22inch Turbine Wheels
apfleisc
73
23
Indianapolis, IN
Not helpful.
Also, the factory 22's are probably some of the most beautiful rims for this car. Most aftermarket Tesla rim's I've seen look terrible and cheesy. I've yet to see better suited rims for Model X. If I find any, I'll be the first to buy them!
Their 22’s are cheap and fragile. Look good, perform bad over time.
apfleisc
73
23
Indianapolis, IN
Agree, I was going for the "aftermarket-scream". Just wanted to be a little different.
Also, I wanted to widen the stance without having to use spacers.
Are those staggered? What are the width measurements of the front and the back? Do the front rub at all when you turn? Thanks! Trying to buy forged after markets but don’t know what width to go with to avoid rubbing on front. Was thinking 10.5 on back 9.5 on front.
Freshness
12
3
LA
Did anyone ever figure out a good spacer brand/setup for the model X in Factory 22’s?
i second the notion that aftermarket wheels look cheesy on the X. I’ve run fully modified setups with three piece HREs and 3k suspensions. But the X looks best to me on stock turbines. The wheels are just too damn anorexic! Need spacers ASAP.
Paul8810
228
261
AZ
Here’s my setup with 20mm spacers all the way around. Love the look, but definitely affects range.
Paul8810
228
261
AZ
Purchased at
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech, based out of Reno, NV I believe. They custom build them so it takes a few weeks, but highly recommended.
This is what my invoice indicates:
5x120 Bolt Pattern, 64.1 Hub. Design3 Aluminum, Silver Billet Finish, Thickness=20mm (0.79in)
I don’t have specific range loss estimates, I guess it could have been due to other factors. Either way, worth it IMHO.
DIL
850
454
Danville, CA
Purchased at
and in the snow, are these any good?
rb951
Murrieta, CA
Purchased at
Thanks for the info!
djillusion
292
126
Chicago
Purchased at
only other question from my side is: 20mm eats up a fair amount of the bolt thread. did you have to get this addressed or do the standard lugs have enough thread left to properly seat/torque?
the 22's look great pushed out a bit more; which has me thinking too. i assume the air suspension will auto adjust to ensure no rubbing.
djillusion
292
126
Chicago
Here's a good xplainer vid:
thanks for sharing! That helped a lot. Looks like 20mm in the rear works well but going with 10 or 15mm is a wiser choice for the front to avoid any rubbing at all when turning.
Also I couldn’t tell from the video but do at what torque specs do you seat the spacers with those nuts? It makes sense that the spacers actually have the additional length of the lugs to accommodate the 20mm push out.
rb951
Murrieta, CA
Purchased at
Just ordered mine today. Lenny, the owner was very informative and great to deal with. He states that with 20mm all around, there is no need to modify original lugs. Should deliver within 2-3 weeks. Will post some pictures once installed.
djillusion
292
126
Chicago
excellent! yeah, take some pics. i won't be installing mine until i put my 22s back on in the spring time - doubt i will run them with my 20s for the winter.
torque the nuts that seat the spacers to 140 (found that out today too).
