Polar993
Most rims, including Tesla’s, have cutouts/holes that in the exact place where the OEM hub studs and nuts protrude. So there is no problem mounting the rims on the spacers.
I now have 21” arachnid wheels on my car with 30mm spacers on the front and 20mm on the rear. There were no mounting problems of any kind. I’ve run spacers on my Model S for about two years and there have been no problems. Nonetheless there are still many folks who are adamantly ant-spacer. Perhaps that’s because they’ve seen examples of the consequences of poor spacer installations, which can be very bad.
You have to have the highest quality spacers and they must be both wheel and hub centric. The torque for both the spacer and wheel lug nuts must be carefully set to 129 ft/lbs. And you must use hard steel lug nuts, not the aluminum ones that many spacer shops supply. If you do it right, there will be no issues.
Thanks for explaining how the OEM studs will recess into the holes of the wheels. Does anyone know if the 22" Turbine wheels on the Model X have these holes?
I agree with you that running spacers is not an issue if you use good quality parts and install them properly.
