When closing door windows roll up then down slightly
Discussion in 'Model Y: Interior & Exterior' started by Velcade, Mar 3, 2021 at 8:23 AM.
  1. Velcade
    Velcade Member
    Midwest
    Does anyone else have this gap in their front windows? I don't have the same issue on the rear doors.
    Is this a 'feature' to prevent the doors from icing shut or should I make a service apt
    Thanks!
  2. Pianewman
    Pianewman Member
    Fort Worth
    The window isn't fully closed in the photo. If it's below a certain temp, the windows will close and then open a small amount, to prevent possible icing.
    What was the ambient temp? Is this only an issue with the driver's window?
  3. scabbotts
    scabbotts Supporting Member
    Maine
    I actually have the same issue on mine. It is the driver's window. It started right after one of the updates, although i also installed new puddle lights, so it may have been that. A couple of times it has gone all the way up, but the majority of the time it is just a little bit low. Be interested to see if anyone else has the same issue.
  4. Pianewman
    Pianewman Member
    Fort Worth
    scabbotts: Does it fully close and then open slightly? That's how the "icing" avoidance works.
  5. scabbotts
    Maine
    Yes that is correct, it goes all the way up and then drops just a little bit. But it is only on the driver's side window. I hadn't heard of the icing avoidance but you are probably right, because there have been days where it does go all the way up and stay up. Well that takes a bit of worry off of me. Now it just looks like my heat pump sensor is the only issue. The heat seems to work when i remotely turn on the heat but when i get in the car and start driving i get very little heat. I knew i shouldn't have read that post. It was fine until the very next time i got in the car after reading about that.
  6. Pianewman
    Pianewman Member
    Fort Worth
    scabbotts: Strange. If it's cold enough, ALL 4 windows should be doing the same thing. Full up, then "zzp", open a very small amount.
  7. Velcade
    Velcade Member
    Midwest
    This is what I'm seeing. It's what made me think it's a 'feature' since I don't see the same thing when I get in the car it rolls up and stays up. This only happens when I get out and I haven't had the car when the temp is above 50
  8. clyde
    clyde Member
    Cincinnati
    I have the same situation, with unpleasant consequences: wind noise from the front windows at 60mph+.
    I reset the top stop of the windows, but the wind noise remained. Only way to reduce wind noise: blip each window button down for a split second, so it's slightly down from its upper stop. That somehow reduces the wind noise. Go figure. Tesla Service is coming out in two weeks...
  9. scabbotts
    Maine
    I guess maybe they would if i opened them and closed them. The other doors don't get used as much as the drivers door, especially the rear doors. I don't have any wind noise like clyde so i am assuming they go all the way up when i get in and drive.
    Thanks for the information!!!! It puts me at ease now.
  10. Pianewman
    Pianewman Member
    Fort Worth
    All 4 windows should be opening that small amount when you close/lock the car. It's not just the door/window you just opened/closed,
