When I ask to navigate a route to Vegas...
Discussion in 'Model S: User Interface' started by Elliott P100D, Jun 28, 2017.
  1. Elliott P100D
    Elliott P100D Member
    Traverse City area, MI
    From my home in northern lower Michigan (By Traverse) to Las Vegas Nevada. It choses the most direct route, what if I enjoy driving again and I wanna go another way... can I ask to direct my passage through Oklahoma city per ce? I've tried and so far only failed. Is there a multi path option button I need to select, maybe I'm not entering my navigation request properly, or is there an Easter egg I need to find?
    Thanks my friends.
  2. chillaban
    chillaban Active Member
    Bay Area
    No multi-waypoint planning currently, unfortunately. It's one of the most frequently requested features from the nav!
    In the meantime, you can use desktop route planners like "A better route planner" to approximate the route (and convince yourself it's possible). Once you have that you can just drive one waypoint leg at a time, and at your final SC, look at how much you need to charge to get to the next one.
  3. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    No, if you dont want a direct route you have to navigate to the place you want and then start a new navigation to the next place.
  4. Elliott P100D
    Thanks. I understand.
