When I put the car in Park the passenger door opens
Discussion in 'Model S: User Interface' started by AprilDelivery??, Dec 17, 2013.
  1. AprilDelivery??
    NY
    I have a S60 and when I switch from drive to park the passenger door opens. It started to happen just a few days after I upgraded to 5.8. Yesterday I upgraded to the latest software after that. Does it have to do with the new software 5.8?
  2. Apoclyps
    Apoclyps Member
    Taipei, Taiwan
    I also have an MS60 with an April delivery. My passenger door started popping open in the past 3 weeks, intermittently. Mainly when I closed my driver side door the passenger door would pop. I think it had to do with the colder weather we are having here in CA. I brought it to the Service Center, but could not replicate my problem, but did mention that the mechanism was a tad more sensitive than the rest of the doors, which would explain it popping open when I closed the driver side door. They replaced the door handle and mechanism today. Will see if it fixes the problem.
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Note the date and time the next time it happens, and report that to the service center. They can check the logs to see why the door opened. Very probably they will then schedule you in for a new door handle.
  4. Krugerrand
    Krugerrand Well-Known Member
    Gee, not sure this is a problem, particularly if you have a passenger. Would be cool if the door automatically opened. Come to think of it, Tesla should change the firmware so that if there is a passenger in the passenger seat, when the car is put into park, their door opens automatically for them. :wink:
  5. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    You're probably joking, but this is a bad idea. If you are parked at an incline, the door would swing open on its own.
    - - - Updated - - -
    Apoclyps, I can't recall, do you have the newer handles or the original style? I know we got our cars around the same time, but seem to remember yours being built before mine and thus perhaps didn't have the newer handles?
  6. NJS1207
    NJS1207 Member
    New Jersey
    I had the same issue, which was fixed by replacing the handles. My understanding from the service center is that they will be able to resolve the problem in the future through the software.
  7. AprilDelivery??
    NY
    I'm VIN# 8988 and I received it in May 5. I'm going to call service today. But this should have happened a few months ago like when I first got it?
  8. malcolm
    malcolm Active Member
    A number of people reported pressing the accelerator pedal and getting a stupid grin on their faces. 5.8 fixed that for some of them.
  9. TylerCA
    TylerCA Member
    portola valley, ca
    I hope they fix this issue especially if there are kids sitting back there.
  10. Chipper
    Chipper Active Member
    Chattanooga, TN
    Chuckling loudly!
  11. smd
    smd Member
    Lafayette, CA
    I updated to 5.8 (1.39.60) two days ago. Now I have TWICE had the rear passenger door pop open slightly when I put the car into P. I've driven about 10 times, so it's less then half the time. I will inquire with the service center if the old-style door handle is the issue.
  12. cinergi
    cinergi Active Member
    MA
    I've only ever known it to happen because as the door handle extends (which happens when you put it in park), it triggers the sensor that's used in detecting a pull so the car thinks someone's pulling on the handle. Interesting though that it's not happening at other times (I'm assuming) -- e.g. unlocking the car.
  13. AprilDelivery??
    NY
    OK , I went to Tesla Service Queens and they changed the insides of the front passenger door handle. So the handle doesn't open when I put in park. It took them like 4 hours , fixing it then a test drive, it took the whole day 9-5.
  14. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I think you ordered the "Mother in Law" option!
  15. lloyds
    lloyds Active Member
    Bay Area
    LOL good one
