When is structural battery pack & 4680 cells coming & Why are you not waiting until then?
Discussion in 'Model Y: Battery & Charging' started by Guvnah, Feb 15, 2021.
  1. DonaldBecker
    DonaldBecker Member
    Which design aspect are you talking about?
    The Tesla Battery Day presentation covered one possible construction change, a 'tabless' battery. This uses electrode foils that are laser patterned on the edges so that they can be crimped over on each end to substitute for welded central tabs. These crimped ends provides a shorter thermal and electrical path.
    The shorter path is an enabling improvement for large cells, which otherwise would have problems charging and cooling, but there is nothing that stops the approach being used with the current cell sizes.
    There are many other battery advances being talked about, so that many not be the one you are referring to.
  2. LevelHeaded
    LevelHeaded Member
    Salt Lake City, UT, USA
    Years away
  3. DanDi58
    DanDi58 Member
    Dayton NJ
    I just listened to the 3-hour Joe Rogan podcast with Elon. I really wish Rogan knew a little more about Tesla as it would have been a great opportunity to ask Elon a lot of these questions and get some clarity, instead of spending 30 minutes talking about the new Roadster hovering. :confused:
  4. Langzaiguy
    Langzaiguy Member
    United States
    I have concerns about its structural design. While I know Tesla batteries are top notch and generally pretty reliable, I've heard many stories of packs or modules being replaced out of warranty. My assumption is that this can't be done with the 4680's. I also wonder about insurance ramifications. I can just picture myself running over something on the highway, only to total the vehicle because the pack is damaged. Hope this isn't the case!
  5. DonaldBecker
    DonaldBecker Member
    People have the impression that a 'structural battery' would involve the cell cases being welded directly to the body, or that removing a battery module would cause the car to collapse under its own weight.
    The current design is that the battery is packaged as modules. The modules are sealed, and are replaced as whole units. If Tesla switches to larger cells assembled as a structural battery, presumably the modules would look exactly the same externally. The only difference is that an updated body would expect that the battery module carries some of the dynamic load. The body itself would still be rigid enough to carry the static load, so modules could be unbolted and replaced without additional support.
    A related example is the windshield on a modern car. Until about a half century ago most windshields were held in loosely place by a rubber gasket that was spread by a trim strip to hold the glass in place. There was a switch to structural windshields that were bonded into place to provide both rigidity and roll-over support. The vehicle will flex much more without the glass in place, but it's replaceable with no special consideration for temporary support.
    • Informative x 3
  6. colea
    colea Member
    Clinton, NY
    Because the lease on my previous car ended last month?
  7. jerry33
    Texas
    Once that comes into production, there will be something new down the pipe that you should also wait for. This is also true for any other high tech item. Using that as a principle, you'll never buy and will miss out on the enjoyment you could have had.
  8. LevelHeaded
    LevelHeaded Member
    longevity of the current pack is not a concern. Wouldn’t be unusual to get 1000+++ usable charge cycles out of the current pack, which would put the pack at far miles than the rest of the car is going to last (300k+).
  9. Devils son
    Devils son Active Member
    Omgeving Eindhoven
    Maybe because they live now.
  10. Guvnah
    Guvnah Member
    Portland, OR
    That's a great reason! If my lease was ending I'd be hopping on the Model Y for sure! I have an older Model S so I'm trying to figure out when to move on...the Model S changed so much since the early models...
  11. Guvnah
    Guvnah Member
    Portland, OR
    Yeah, sure, but if the structural battery pack with 4680 ends up improving range significantly as well as increasing charge curves and longevity due to thermal management improvements then I am trying to figure out if its worth waiting for. This seems to be one improvement that is more significant than others (ie. wood trim on the doors, console, etc.). I don't think there will be huge advances in "tech." right around the corner after the 4680s...!?
  12. Guvnah
    Guvnah Member
    Portland, OR
    A 1000 or more cycles? Did I get that right? What do you think battery degradation for the current packs will be after that many cycles?
    Tesla Bjorn has what 8% degradation after two years? (after 80km?)
  13. DonaldBecker
    DonaldBecker Member
    He uses the battery hard, with full cycles discharges and recharging using Superchargers, in a harsh environment.
    Considering that degradation is initially steep, then has a shallower slope, his experience is a pretty good indication that battery life won't be a problem for most vehicles and users.
  14. LADude23
    LADude23 Member
    Los Angeles, CA USA
    This technology is still changing very quickly, and many competitors will be entering the market in the next couple of years. I'm waiting on delivery but I'm doing a 3-year lease for the first time in my life, partially because I'm now in business for myself and can deduct a payments, but also because I really don't want to invest in such a rapidly changing technology.
  15. Exelion
    Exelion Member
    Los Angeles, CA
    Waiting for the Model Y to get 4680's? Don't hold your breath. When the 2170's came out, did the S and X get them? No, they didn't get those right away. Why? Because Tesla was already cranking out cars in a production process. It would take a really compelling reason for them to change the design, and change the factory to crank out 2170 S's and X's. So 3's and Y's got those batteries.
    If any current designs would be getting them, it would be Berlin and Austin plants chugging those out, but those factories aren't up and running yet. That will take......time.
    I really think the Semi, Cyber Truck, and New Roadster are the cars qualified to get the 4680's, as those aren't in production yet. Maybe one, maybe all three. But waiting for Fremont 3, Y, S, and X to get those batteries? Slim chance, and not probable.
    Lastly, when they DO come out, let's say the S,3,X,and Y do get the 4680's, how much do you think they'll cost? Not significantly less. Tesla would structure the pricing accordingly with their naming conventions and subtly edge people to buy the longer range models for more money, what they think many people would spend for them.
  16. SactoEVer
    SactoEVer Member
    Sacramento
    Any thoughts on whether we'll see a notable improvement on the current range before before the 4680s are incorporated?
  17. Exelion
    Exelion Member
    Los Angeles, CA
    This is entirely possible, because battery makers are always trying to cram more longevity into their current designs. Latest I saw was a 5% increase (which doesn't sound like a lot) which is a really nice thing because:
    -It doesn't disrupt the production line. The batteries are the same physical size and packed the same way, just that each battery has a tiny bit more juice.
    -If they continue to do this, in four years that is 20% increase from yesterday, which is now a LOT. Optimistic projection and purely speculative, but its nice to dream sometimes.
    -Pricing is still the same, hasn't increased 5% to match the increased range (ssssshhhh keep this quiet!)
    -The only thing better than a 5% increase via battery mfg is 5% increase from software updates, and those have happened before too. Any increase of range is ALWAYS welcome, no matter how small they may seem.
