Ok, well the obvious answer is that everyone should be rotating tires according to the tire manufacturers recommendation in order to not void the tire's treadwear warranty. This is usually every 7500 miles.
Tires benefit from an early rotation so that every tire has a turn on the drive axle. This helps set up an even wear pattern that helps prevent odd wear and vibration later in the tire's life. Typically this should be around 1600 miles for a tire that's expected to live 30,000 miles or longer. Obviously it's not going to help that much if your tires only last 6,000 miles.
After that rotation is mainly so that all four tires will wear out at the same time--always best to replace tires in sets of four (assuming they are the same size). The main reason that it's best to replace tires in sets of four is that tire manufacturers make undocumented changes to the tires and putting on four at once is the best way to make sure the handling characteristics are balanced.
Thanks. So what do you recommend for the 21" Conti tires if they look to only last around 10-15k miles? I'm down to a little over 5 mm after 6,000 miles and rotated at 2,500. We only get 2 free rotations per year.
I took mine to a local tire place to get them rotated around 6,200 miles. I wish I had paid better attention to the fact that Tesla does it for free.
Really? Where do they state this? (That's cool if they do.)
Is that really in the Texas service plan?Tesla will rotate tires twice a year as part of the service contract.
The plan I am offered in Washington reads as follows:
The regularly scheduled maintenance inspections shall include the following (subject to change by Tesla
at any time and without notice, in its sole discretion):
•Vehicle inspection;
•Replacement or repair at the time of inspection of normal maintenance items
and wear and tear parts, excluding the Battery and tires;
•Wheel alignment*; and
•Tire rotation*.
As I read it, "The regularly scheduled maintenance inspections" means yearly or 12,500 mile intervals.
