Where are the Auto Windshield Wipers?
Discussion in 'Model S: User Interface' started by BestRadar, Jan 26, 2017.
  1. BestRadar
    BestRadar Banned
    NJ
    #1 BestRadar, Jan 26, 2017
    Where are the Auto Windshield Wipers and Auto High Beams? Shouldn't these be some of the easier projects to get done? Also, I have not really noticed any benefit from Adaptive Lighting. Is this working? On my other 2 cars when I make a turn you can clearly see the light moving towards the direction I am turning but I dont notice this on the Tesla?
  2. Boatguy
    Boatguy Member
    SF Bay Area
    At least on my S90D they are both there.
    Auto wipers is on the stalk, two different sensitivity settings are the first rotations from OFF.
    Auto High Beams is enabled in the Controls, and then the stalk must be pushed away from the wheel and remain in that position. When they are enabled the high beam indicator on the instrument panel has an A in the middle.
    The above is documented in the manual.
    Can't help you with adaptive lighting.
  3. lunitiks
    lunitiks Cool James & Black Teacher
    Prawn Island, VC
    The true mystery of the world is the visible, not the invisible
  4. MorrisonHiker
    MorrisonHiker S 100D 2019.16.2
    Colorado
    The hardware is there. The software hasn't enabled them in AP2 cars yet.
  5. Saghost
    Saghost Well-Known Member
    Delaware
    Tesla's implementation of adaptive lighting is a little different, and the graphics don't explain it well.
    The high and low beams don't move on these cars; instead, a series of three additional LEDs on each side progressively illuminate as the wheel turns, or all together when the turn signal is on.
    Bjorn has a nice video showing it that I'll try to add when I get to a computer.
  6. MorrisonHiker
    Colorado
    Here's the video you mentioned:
  7. BestRadar
    BestRadar Banned
    NJ
    #7 BestRadar, Jan 26, 2017
    Thanks.. The video helps explain the feature but it's a disappointment compared to the lighting I am used to. With both my other vehicles the lights actually move putting all light towards where you are going. These extra LED's only light up a small distance and would explain why I never noticed anything.
  8. Spidy
    Spidy Active Member
    EU
    The issue isn't even the lack of movement part. Audi Matrix light and Mercedes new adaptive headlights operate in the same way with LEDs, but as you said Tesla simply seems to lack the LEDs with the distance at the right angle for taking corners at higher speeds.
