Where do I go to get Daytime Running Lights back???
Discussion in 'Model X' started by Buckeye4, Jul 10, 2019.
  1. Buckeye4
    Buckeye4 Member
    Gahanna OH
    My 2016 X last couple of updates featuring dog mode enhancements mentioned nothing much else. Yet driving at dusk, I noticed I'm completely dark, no headlights even when set to auto, and worst of all no DRL. Hope whoever took the safety enhancement is enjoying it. As far as I can see, there is no way to get them back. Help!
  2. ValleyGeek
    ValleyGeek Member
    North Bend, WA
    That's very odd indeed, do they come on when you manually set them to the "driving" position? It should be on the first screen when you open the menu on the MCU or under the "Lighting" category on the left in that menu.
  3. RecklessFury
    RecklessFury Member
    Also verify that you are not in range mode. Range mode disables the running light from my understanding.
    • Helpful x 2
  4. ShawnA
    ShawnA Supporting Member
    Edwardsburg, MI
    Hi Buckeye4,
    Your only choices currently are to manually turn on parking lights and headlights...
    It seems your sensor or light controller has died - it's time for service...
    This looks like an issue where one of their mobile service personnel could help...
    Good luck,
    Shawn
  5. dashrb
    dashrb Member
    Fairfax, VA, USA
    RecklessFury is right: enabling range mode disables DRL in the X (but not in the S). Unclear why, those lights can't be a big drain on battery, and certainly reduce safety.
  6. Buckeye4
    Buckeye4 Member
    Gahanna OH
    Thanks for the suggestions. The lights turn on manually and stay on and complain when I park if not turned off manually. Not in Range mode, never have been. Seeing the lights come on mostly when parked in shade and fail during drive if hot. Have an appt for service.
  7. Silicon Desert
    Silicon Desert Active Member
    Sparks Nevada / GF 1
    Hmmm, never happened in my MX. I keep range mode on and doesn't affect running lights from what I have ever seen. Maybe depends on software version, maybe not, yet I've gone through a bunch of updates with no change.
  8. Silicon Desert
    Right, however, the lights will still turn off anyway when you leave the car and walk away.
  9. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    This happened to me once back when the car was just 4 months old. I could get the lights to turn on if I toggled the high beams on and then they would turn off again after a few minutes.
    I did the power off button and waited 5 minutes and then pressed the brake to turn the car on again. Has never done this again.
  10. Buckeye4
    Buckeye4 Member
    Gahanna OH
    That sounds like a winner. I'll add a couple of reboots for good measure and let you know. Thanks a lot.
  11. ytwytw
    ytwytw Member
    Canada
    Maybe US region only problem?
    Im in Canada and I always have DRL due to the law requires it here
    Its always on regardless of the range mode
  12. Buckeye4
    Buckeye4 Member
    Gahanna OH
    Sorry to report: No Joy.
    In contact with Service Team reviewing the logs.
  13. Buckeye4
    Buckeye4 Member
    Gahanna OH
    Well Service looked at the DRL "Signature" lights otherwise known as Daytime Running Lights and said I should be glad to be saving power by having them switch off 4 minutes into every trip. It's a Feature not a Bug. And I'm not supposed to choke on all the smoke being blown up my anatomy.
    I guess I'm not alone, starting to notice a few other X's running without benefit of DRLs. Wonder how many other drivers are aware? Probably not too many judging by the lack of notice on this and other boards.
    Some typical screen shots: DRLs on up to 4 minutes into a trip; Off after.
    IMG_2852.jpg IMG_2842.jpg This is borderline pathetic. Quality Control wherefore art thou?
  14. Tam
    Tam Well-Known Member
    Visalia, CA
    I think the green / blue headlight icons in the instrument clusters are indicators for bright headlights and not their surrounding lights.
  15. Buckeye4
    Buckeye4 Member
    Gahanna OH
    Tam, thanks for your input.
    It's Daytime.
    Lights are on.
    4 Minutes elapse.
    Then Lights are off.
    It's a safety issue.
    Am I the problem for fuzzing up the nomenclature?
  16. Tam
    Visalia, CA
    I am specifically puzzled about the headlight icon on your instrument clusters.
    I am assuming you would like all lights are on during daylight, am I correct?
    My understanding is headlights are meant to be bright enough to illuminate the road while DRL are dim lights at the front of the vehicle and are not meant to be bright enough to illuminate the road.
    The instrument cluster does tell us whether the bright headlights are on or off. When the headlight icon is on it also means the rear lights are on and DRL are on too.
    However, there is no specific icon for DRL---those dim lights at the front of the vehicle not meant to illuminate the road.
    So, by showing your instrument clusters, how do I know whether your DRL is on or off when the headlight icons are off?
    DRL is not the same as Headlight. Some stretches in California, turning on DRL is not enough, you have to turn on headlights even in daylight.
  17. Buckeye4
    Buckeye4 Member
    Gahanna OH
    Yeah, Tam, It's complicated. What I sense from the dash is that initially, enough lights are on to illuminate the roadway, so obviously, there's enough light to be seen from a distance. Later, there seems to be no light at all. I will verify this with exterior shots taken by the wife I hope. So more to come...
  18. Tam
    Visalia, CA
    I believe you. There's no need for the pictures.
    Like you, I am also concerned that automatic on headlights and the DRL at dusk are not functioning.
    I hope this issue is fixed soon.
  19. Buckeye4
    Buckeye4 Member
    Gahanna OH
    Thanks for this discussion. It's very useful. And you make very god points.
    I'm like trying to present a case without an attorney, thinking it is so clear and obvious when that is hardly the case.
  20. Shateam
    Shateam Member
    NJ
    I think your Service Center is providing you with incorrect information. There is no display indicator on the Instrument Cluster for DRLs.
    Your top screenshot indicates that your headlights are illuminated. This is confirmed by the Green headlight icon on the top left as well as the white “glow” in the front of the car rendering.
    Your second screenshot indicates that your headlights are off (no green light icon or white glow), probably because you’re driving during the day.
    DLRs for U.S. cars is controlled by Range Mode as mentioned in previous threads. If you have Range Mode “off” your DLRs should be illuminated. If they are not, you have an issue. Have someone drove in front of you to confirm.
