Where to buy the NEMA 14-50 female socket?
Discussion in 'Asia and Australia' started by Bennny, Sep 18, 2016.
  1. Bennny
    Bennny Member
    Victoria, Australia
    I've tried Clipsal direct, Middy's, L&H, all with no luck. Any ideas where I can source one?
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Amazon has them. Search nema 14-50r
  3. miimura
    miimura Well-Known Member
    Los Altos, CA
    If you're in Australia, why do you want a NEMA socket? The equipment supplied by Tesla in Australia does not use NEMA plugs. The standard one provided uses a normal Australian 10A plug. EVnomics is the best source for Australia specific charging equipment beyond what is provided by Tesla. This includes J1772 to Tesla adapters, 3-phase Australian plug adapters for the Tesla Mobile Connector, etc. I believe they also import 32A 3-phase portable EVSE from Europe for Australian customers. However, that is not on their web site.
  4. Bennny
    Bennny Member
    Victoria, Australia
    Aha! That's why I can't find them :)
    So the charger just plugs straight into our typical three pin socket?
  5. miimura
    Los Altos, CA
    Yep. It plugs straight in. Tesla also has their hard wired Wall Connector available in single phase and three phase models available at extra cost in Australia. You can also special order the European 16A Red three phase adapter for the Mobile connector and EVnomics can supply the Clipsal adapter tails to connect to Australian industrial sockets.
    I just looked at the Australian version of Tesla.com and it was woefully lacking information about home charging.
  6. Bennny
    Bennny Member
    Victoria, Australia
    Absolutely! Hence the confusion with the NEMA plug.
    I did, however, manage to find this link hidden away. They ought to put this info under charging also:
    Home charging installation
