Where to place ExpressToll switchable HOV Transponder?
alleycat
14
69
Boulder, CO
Question for those living around Den/Boulder. Have any of you installed the ExpressToll switchable HOV transponder? If so, where on the windshield did you place it to be successful. Our DS said anywhere on the tint (so does the manual), but that was contrary to what some people wrote on TMC about their Easypass. Thanks in advance.
swesson
134
181
Denver, Colorado
I mounted my sticker just under the autopilot camera and it works just fine.
Reactions: cclaygo
cman8
322
74
United States
On my windshield (and in the manual) it shows to place them right next to the AP camera. theres a spot where its all black without any coating on it for transponders.
Reactions: Roentgen
Farnigus
30
18
I actually have two different fast-track organizations that I can take to work depending on traffic, so rather than mounting it permanently, I just hold the transponder up to the windshield as I drive through.
If you forget, its not the biggest problem in the world since there is a license plate reader that they will use to track you down.
So, if you're not sure where you want to mount it, just spend some a week holding it up to the windshield to see if it will work before attaching it semi-permanently...
Generally speaking, I think anywhere around the rear view mirror is fine
MSFtog
New Member
Aug 6, 2016
4
0
Boulder, CO
I mounted mine over the left shoulder of the driver, in the corner of the windshield. Works great and it is out of sight.
The manual for the X says to mount transponders in the upper section of the windshield (the area above the rear view mirror). I like that you've put it on the left side so that it's not smack dab in the center. The tinting and location aren't a problem, then?
swesson
134
181
Denver, Colorado
No. It works great. Haven't had a misread yet.
vandacca
ReActive Member
Oct 13, 2014
3,371
2,202
Hamilton
It's best to mount these transponders below the mirror if you ever intend to use the tesla-provided sunscreen. I learned that the hard way. :(
aesculus
Still Trying to Figure This All Out
May 31, 2015
4,301
2,460
Northern California
No need to hold it. Just place it on the top of the dash inboard of the edge in the center. I keep mine in the little tray just above the large cup holder bay and grab it when I approach the toll area and put it away when safe after passing.
