The question says it all. I know where it worked on my Model S. There nothing in the Model 3 manual talking about it. Any ideas?
Ive placed mine in both locations here. Attached to the glass up against that pillar between the roof and rear window glass. Not in my line of sight while im driving and still works fine. I have the newer candy bar shaped transponder.
It will be years, years I say, before you ever get your car because you are on Elon's naughty list. By then, Model 3's wont have bumpers, oh wait, they don't have bumpers now. By the time you get your car, the transponder will be integrated into the U.I.I'd like to try and put mine behind the front bumper. Hopefully someone tries that before I get mine so I know if it works…
I've placed my EZ Pass transponder in the bottom of my center bin under assorted other junk. It has worked every time. I think the receivers are much more sensitive than they used to be
Which type of Flex Pass do you have - the former kind or the "candy bar" type?
When did he Candy bar type come out?
Thanks for info.
Apparently the new version of the Model 3 manual has information on where a transponder should be mounted. The right side of mirror mount housing.
BTW, if you use the Metro or I-680 express lanes, you need a Flex transponder: FasTrak® - Keeping the Bay Area Moving
It's not available in the "candy bar" format, just the old square format with a switch you keep on "3" for Teslas.
