I have 10 days until it’s set and cured. My commute is 100 miles round trip. There is a supercharger 25 miles from my work (Further away) I work alternating 12-9 and 9-5 shifts. So take tomorrow, 12-9 I’m at 140 right now. I’ll be at 190 when I leave, I’ll get home with 90 and only be able to charge from 11ish to 7ish that will be 140ish. I’d have to drive 30 minutes in the opposite direction then back almost every 3 days, and that might be pushing it. I was looking for a better temporary solution. Oh well...
Has anyone actually tried, and currently using some (all?) of these suggestions for adaptations?
The removable plug on the end of the UMC is actively read by the UMC. This information is used by the UMC to communicate max charge rates to the car and to test the circuit for faults. If you use the 14-50 adapter plug on the UMC, and connect it via adaptation to a TT-30, it will still only supply 120V to the UMC. I would expect the UMC to detect a circuit fault and throw an error, as it is expecting 240V. With the 5-15 ("normal" 120V plug) UMC adapter plug installed, no matter what the source is via adaptation, the UMC/car will still only allow a maximum charge of 12A. If you got the 5-20 UMC adapter plug, you'd be able to bump that up to 16A max continuous, but still at 120V.
I agree with others that have suggested having your TT-30 converted over to a 14-50 and using a short as possible extension with your 20' UMC to reach your car. If you still need a TT-30 receptacle, you can use a built/purchased 14-50 to TT-30 adapter with no problem. Bottom line, regardless of panel/breaker/wiring, the TT-30 is only rated at 30A peak (24A continuous) and only wired for 120V (hot-neutral-ground). I don't believe a UMC with the 14-50 plug on it will engage charging with one of the hot terminals dead.
Ahh, very interesting, I may have to play around and do some testing now. I know the UMC identifies which adapter plug is connected, and I know the UMC does line fault testing prior to and during charging. I've read it will throw a line fault error if your voltage drops too low, and I've read that Tesla states their 14-50 adapter voltage range is 208-250 (covering split-phase to three-phase). I assumed that below a nominal 208V it would throw a line fault error.The UMC only passes two power wires down to the car - it's just that the 120V plugs pass L and N, and the 240V pass L1 and L2.
The UMC only knows the plug ends to the point of knowing the proper maximum current level for each - I'm pretty sure it'll have no problem with 120V on a 14-50 - as long as that comes in on L1 to L2 (which is why you need an EV designed adapter which connects neutral to one line and leaves the 14-50 neutral floating instead of an RV designed one that puts L on both L1 and L2.)
I guess if the ID pin only instructs the max amperage, and doesn't identify the expected voltage, that would work like a champ!
I've used a TT-30P to 14-50R adapter while camping (current set to 24 amps in the car, of course). It works.Ahh, very interesting, I may have to play around and do some testing now. I know the UMC identifies which adapter plug is connected, and I know the UMC does line fault testing prior to and during charging. I've read it will throw a line fault error if your voltage drops too low, and I've read that Tesla states their 14-50 adapter voltage range is 208-250 (covering split-phase to three-phase). I assumed that below a nominal 208V it would throw a line fault error.
I'm completely not sure. I've never seen it myself. I've only read where a couple people said they threw a charging error, and when their electrician checked it, they had low voltage. He then called their energy supplier and they came out to fix it. Not being there to see it, I'm now guessing that the line could have been unstable, which caused the fault, and the low voltage was probably just a bi-product.Are you sure the UMC is throwing an error for low voltage?
I'm sure that the car will, but less sure that the UMC itself will.
Most of the "low voltage" errors are voltage drops. That is, the voltage detected drops as the current draw increases compared to the initial voltage before the car starts drawing current. They are detecting high resistance this way.I'm completely not sure. I've never seen it myself. I've only read where a couple people said they threw a charging error, and when their electrician checked it, they had low voltage. He then called their energy supplier and they came out to fix it. Not being there to see it, I'm now guessing that the line could have been unstable, which caused the fault, and the low voltage was probably just a bi-product.
of course that would only work if your two outlets are on different legs of your 240 serviceProbably too late now by what about this item Amazon.com: Camco 55025 PowerGrip Maximizer 45 AMP Adapter: Automotive?
Actually, this adapter is trying to combine both hots together in parallel, to create one 120V powered leg on the 14-50 receptacle. You'd want them on the same side of the 240V split-phase. If they were on opposite sides of the 240V split phase you would have an explosive reaction.of course that would only work if your two outlets are on different legs of your 240 service
Please, for the love of Tesla (and yourself, and your family) nobody buy this adapter, please!Probably too late now by what about this item Amazon.com: Camco 55025 PowerGrip Maximizer 45 AMP Adapter: Automotive?
