Thanks. That's ridiculous, it probably cost them few $ to make. Should be standard, like it was in 2019.
Personally I have no use for anything except the standard 120v power cord and the adapter to charge from non tesla stations which both came with the Y. Both are stored in the car for emergency use if required. Ideally a wall connector is the ticket when at home IMHO. Not only is it convenient but since it is connected to wifi, charging parameters can be modified if something more efficient or a different algorithm for battery charging parameter longevity comes up.
Guessing you live in a pretty populated area with lots of Chargers... Alaska just isn't there quite yet. So 14-50, 5-50, TT-30 are also important. But that's my problem not everyone elses.
Yes there is a good population however the superchargers are far and few between around here. I charge at home and at the office having only used a supercharger 2x so far. Do not understand where one can plug in all those adapters you mention as honestly I know nobody that would have anything like that where I could plug into unless they have an EV at home. Never seen a standard garage with a 220v plug in it. Apart from stove and dryer outlet there is nothing I can think of. Only place I could see where higher voltage/current is available would be camp grounds and marinas then again you just can't pull in there to charge either. Please enlighten me on where those adapters get used apart if one wants to install this outlet type in their own garage to charge from.
Personally if I had to go on a very long trip I would fly and rent a car or take the ICE car unless the route had plenty of superchargers along the way. They will eventually come but right now unless you live in a major US city, or are travelling a popular interstate, it is not all that great.
Not exactly. CHAdeMO has been around a while and plenty of those chargers are around too. CCS chargers will rapidly replace both of those. Personally I wish there was a low cost US version of the CCS adapter. CCS fast charging would be a great supplement to super chargers when planning road trips. CHADeMO would too but I don't want to spend that much or haul that massive adapter around (or even keep it in storage until I do go on a road trip where it might be needed.)Without question, the J-1772 is the norm for everyone except Tesla.
disagreePersonally I have no use for anything except the standard 120v power cord and the adapter to charge from non tesla stations which both came with the Y. Both are stored in the car for emergency use if required. Ideally a wall connector is the ticket when at home IMHO. Not only is it convenient but since it is connected to wifi, charging parameters can be modified if something more efficient or a different algorithm for battery charging parameter longevity comes up.
Yes there is a good population however the superchargers are far and few between around here. I charge at home and at the office having only used a supercharger 2x so far. Do not understand where one can plug in all those adapters you mention as honestly I know nobody that would have anything like that where I could plug into unless they have an EV at home. Never seen a standard garage with a 220v plug in it. Apart from stove and dryer outlet there is nothing I can think of...
Only place I could see where higher voltage/current is available would be camp grounds and marinas then again you just can't pull in there to charge either. Please enlighten me on where those adapters get used apart if one wants to install this outlet type in their own garage to charge from...
