That’s how I’ve been doing it. Works great.NEMA 14-50 with a second UMC. Cheapest solution and I've never had to wait for charging to complete.
Very reasonable solution IMHO. Jus the sure to set the WC to a 50a breaker (40a max charge rate).I went with a 14-50 and added a plug to a Wall Connector. I went this route so that I have the flexibility to use a welder or use a mobile connector if the Wall Connector gave me problems.
Of course, you could just as easily take a hard wired solution with you if you move.I installed a 14-50 outlet and I chose to use a Juicebox. I did not want a Tesla hard-wired setup. If I move I can unplug and take this thing with me. If it fails I simply buy another one and plug it in.
I installed a NEMA 14-50 (three actually) and for the Model 3 I purchased a second mobile connector. At $300 it is inexpensive and fully meets the need.Hello all,
expecting delivery shortly and wondering which charger people are using? and why?
i called an electrician that installs plugs for tesla and he said that he would install the plug for the portable charger with adapter. When I asked about the wall charger installation and he had no idea what I was talking about LOL. This was a "tesla certified" installer and he didn't know what the wall charger was?
anyways..... would love to here your opinions.
Thanks
Jason
Hello all,
Thanks
Jason
I am really at a loss to understand spending $40k+ and then worrying about a couple hundred dollar to support it.
The best answer and if it is feasible and if you have the disposable income to do it. Install a Tesla wall connector with as much power as possible up to 100 amp circuit if you can. You'll thank me later at some point. Every other option is a compromise from there, just really depends on what you can live with.
Keep in mind that your home charging solution is not always an overnight solution. There are times when you're going to want to decrease your turnaround time. kids have to go to soccer practice? you want to go out again after you get home from work? Forgot to plug in the night before? Another EV gets added to your stable? Future-proofing is good when you can do it.
I would always recommend getting as much power as you possibly can to the location where your car or car's? are going to charge.
The wall connector can be installed at I believe 13 different amperage settings up to a 100amp circuit.
Yes, a Wall Connector does have an internal adjustment that’s suppose to be set based on a breaker, which I have done (50A). It’s my understanding that the built-in plug Wall Connector version didn’t have the option to adjust to a breaker; fixed at 50A. (Someone please correct me if I’m wrong.) If so, I’d probably opt for the non-plugin version and add a plug like I did for the option to hard wire it and crank up the amps in the future.
I don't recall the instructions, are you supposed to set it to the breaker current or the prorated value of 40 amps?
