This potential solution offers long range, but less power, depending on the design.
Also, it is first generation, so pioneers and arrows and all that.
Sure $2,500/kW upfront (10 x 100W SKLep) is expensive but when factoring in kWhs it gets interesting.
100,000kWhs for $2,500 is $0.025/kWh.
Nothing on the planet can deliver 24/7 kWhs, to your home, for 11 years, at 2.5 cents / kWh.
Leonardo Ecat SKLep
Leonardo Corporation
1331 Lincoln Road,
Miami Beach, Florida 33139
[email protected]
Link: Ecat SKLep
Specifications for the Ecat SKLep
Size: 7 x 7 x 9 cm (2.8″ x 2.8″ x 3.6″)
Weight: 250 grams (8.8 ounces)
Output voltage: 12V DC
Output power: 100W
Power supply: 12V DC
Power consumption: 1W
Power density: 0.23 kW/liter (0.23 MW per cubic meter)
Specific power: 0.4 kW/kg
Expected Operational Lifetime: 100,000 hours continuously
Recyclable: Yes
Warranty: 3 years
Notes: Supply is current limited to 8.3 amps max per unit, but units can be cascaded in series or parallel to increase capacity. Units will shut down if the load limit is exceeded.
Shutdown does not damage the unit which can be restarted after load is reduced.
United States Patent no. US 9,115,913 B1.
US Trademark Registration Number 4808884
Test Report: https://e-catworld.com/wp-content/uploads/2021/12/SKL-MISURE-UNIBO.pdf
$250 for 10,000 kilo-watt-hours is $0.025 per KWH.
100 Watts per unit cascadable in series or parallel for increased voltage and/or current. Nominally, 12 Volts DC at 8.33 Amps per unit 24/7 add inverter as needed.
Leonardo Ecat SKLep
1331 Lincoln Road,
[email protected]
Link: Ecat SKLep
Output power: 100W
Recyclable: Yes
Warranty: 3 years
