Which launches faster: P85/19 or P85/21?
Discussion in 'Model S: Driving Dynamics' started by ACDriveMotor, Sep 24, 2013.
  1. ACDriveMotor
    ACDriveMotor Member
    Seattle, WA
    I've heard that 19" tires have greater contact area. Does that mean that you get better launch from P85/19 over P85/21?
  2. fiksegts
    fiksegts Active Member
    Miami
    I don't spin when launching with my P85 on 21's, so 19's won't be any better....
  3. ACDriveMotor
    ACDriveMotor Member
    Seattle, WA
    Even if they have more contact surface? This is new to me.
  4. Mayhemm
    Mayhemm Model S P85+ "Lola"
    Saskatchewan, Canada
    My understanding is that the 21-inch wheels come with grippier tires, which contribute to a marginally faster launch.
  5. texex91
    texex91 Banned
    hell
    And if you add +, it's even better. 21's all day, everyday!
  6. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Not with stock tires, no. Equivalent tires, the same. The contact patch on the 19"s is a few percent larger, so there's not much chance of it being noticeable even with timing equipment. Given the 21"s don't slip when launching, the additional grip of the 19"s on equivalent tires doesn't buy you anything.
    Equivalent tires, despite the smaller contact patch the 21"s will likely have a slight advantage in the corners due to the stiffer sidewalls. This will be offset by the higher unsprung weight of the 21"s, which is a big factor in how the car feels as it changes direction.
    Finally, I didn't run the numbers but I'd suspect the staggered 21"s on the P85+ have a similar contact patch to the 19"s AND stiffer sidewalls, which would give them better performance both linearly and laterally.
