White door clips and where to buy them?
Discussion in 'Model S: Interior & Exterior' started by No2DinosaurFuel, Nov 10, 2016.
  1. No2DinosaurFuel
    No2DinosaurFuel Active Member
    San Diego, California
    I want to know where you can get those clips to hold the inner door panels to the doors. I plan to replace my sound system requiring me to remove my door panels. The clips might break in the process or better yet replace them all so I don't get door panel creaking after reinstalling.
    Thanks!
  2. CalBlue 85D
    CalBlue 85D Member
    SF Bay Area
    Check out this post, it has the clips listed. They are the same as a Toyota part because Elon just used an old box of them that he found sitting around the old NUMMI plant when he bought it. ; )
    https://teslamotorsclub.com/tmc/posts/796472/
  3. CalBlue 85D
    CalBlue 85D Member
    SF Bay Area
  4. trils0n
    trils0n 2013 P85
    SF Bay Area
    Also, if you live near a service center, they will often give them to you if you ask nicely. (Depends who is working service that day, and how much of a stickler the parts guy wants to be, sometimes they will "have to" write up a work order to sell you the parts, they are a couple cents each)
  5. No2DinosaurFuel
    Thanks for the link!
  6. No2DinosaurFuel
    I don't mind paying. I just want to get the right parts. Thanks for all the replies. Is the one with the rubber better buy or that fits somewhere else on the car? The rubber might help remove some of the rattling.
    Thanks!
  7. trils0n
    trils0n 2013 P85
    SF Bay Area
    Supposedly the one with the rubber has been replaced with an updated version that has a rubbery felt ring nestled into the plastic circle (instead of around it). At least that was what the service center told me when I went to get a couple of them. I used that new part they provided and it felt like it was a more solid attachment than the ones with the rubber.
  8. MDR SEA
    MDR SEA 2015 Model S 85D, 2016 Model X 90D
    Pac NW
  9. David.85D
    David.85D Member
    Maryland
    Bought some trim clips from my service center today. Pricing is very reasonable. Should be the first place most people look.
    I made an image showing the part, the official name from the receipt, the part number and the current pricing in the US.
    BRUSH CLIP 5MM - 22.20MM
    1009399-00-A
    $0.15
    HEART FLEX CLIP WITH WASHER - 70 LBS RETENTION
    1025401-00-A
    $0.22
    NIFCO TRIM CLIP 12733
    1011813-00-A
    $1.00
    TRIM CLIP 1.7 TO 3MM PANEL WITH 7MM HOLE
    1016078-00-A
    $0.81
    RIVET PUSH-PULL 8X18X20.0
    1006521-00-A
    $0.25
    • Informative x 7
  10. David.85D
    David.85D Member
    Maryland
    Meant to add, the invoice says this on it under the Heart Flex Clip "All door panel clips must be replaced after removal."
  11. BigCity
    BigCity Member
    Avon, IN
    Good info!
