White House wants to turn ISS into commercially run venture post-2024
Discussion in 'SpaceX' started by e-FTW, Feb 11, 2018.
Tags:
  1. e-FTW
    e-FTW New electron smell
    San Francisco, CA
  2. Matias
    Matias Active Member
    Finland
    Whatever as long as they aren’t ditching it to the sea.
  3. Nikxice
    Nikxice Active Member
    Hudson, NH
  4. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    As opposed to allowing the station to burn up in the atmosphere, I like the idea of selling it to private interests. The idea was around before the current administration came into office though.
  5. boonedocks
    boonedocks Active Member
    Gainesville, GA
    If this happens, it will be tun cheaper, more efficiently, safer, and a lot more things will come from the worn at the ISS. It’s actually a good idea whether it came from President Trump or a predecessor. Hopefully President Trump will make it so tho!!
  6. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Private corporations may not necessarily operate the ISS “safer” than NASA, since they are focused on maximizing profits, not maximizing safety.
  7. HookBill
    HookBill Member
    The OC, CA
    The ISS programme is a joint project among five participating space agencies: NASA, Roscosmos, JAXA, ESA, and CSA.[16][17] The ownership and use of the space station is established by intergovernmental treaties and agreements.[18] The station is divided into two sections, the Russian Orbital Segment (ROS) and the United States Orbital Segment (USOS), which is shared by many nations. As of January 2014, the American portion of ISS is being funded until 2024.[19][20][21] Roscosmos has endorsed the continued operation of ISS through 2024[22] but has proposed using elements of the Russian Orbital Segment to construct a new Russian space station called OPSEK.[23]
  8. lunitiks
    lunitiks Cool James & Black Teacher
    Prawn Island, VC
    While an interesting idea, I wonder how this would actually work...
    Wouldn’t alphabet, apple or michael jackson just buy the whole thing?
