Who has lost regen with winter tires?
eepic
906
123
Canada
Thanks for bringing attention to this and keep us updated. Putting R3's in mid November on my LR RWD as well
marcn
117
108
Kelowna, BC
Just for another data point - I've been driving for a few weeks now with Nokian Hakka R3's on factory 18" aero wheels and sensors and I have NOT noticed this happening to me. Full regen is available at all speeds (except for when the temperature is actually colder and the car itself is cold, in which case I'll have a few dots to the left of the battery meter showing limited regen, although it's not even enough to really notice).
The temperature here has varied from 5C up to ~20C. AWD.
Reactions: navguy12
5_+JqckQttqck
1,851
1,336
Toronto
This puts the onus on the rims (weight). Very confused at the moment.
mtayag
New Member
Oct 24, 2018
oakville, ontario, canada
I installed the Continental Winter SI on my RWD LR yesterday and immediately noticed this effect. Posted on the Canadian Model 3 Owners group and someone pointed me to this thread. Has anyone reported to Tesla? Anything else we can do to resolve this issue?
Reactions: Darthbenji
Darthbenji
1,003
594
Ontario
So there’s an awd without the issue.
Alysha_D
New Member
May 15, 2018
Burlington
Model 3, just got Nokian Hakkapalitas installed on our aero rims and I immediately noticed Regen issues. I can't one pedal drive. It was about 7C in the GTA today. Looks like it will improve when it gets cooler?
Reactions: akidesir
noicepls
324
241
Lambton County ON.
Regen not be impacted with snow tires. I just installed Nokian WRG4 on the stock aero rims, and after approx. 350 km, there is no range or regen difference. I'm on software version 40.1.
How about checking the car's settings and make sure the Regen is not knocked out of Standard?
Reactions: jsmay311
Darthbenji
1,003
594
Ontario
First thing I checked. You didn’t find the Cadbury secret I’m afraid.
Do you have RWD or AWD? 40.1 gives me hope it’s a software issue.
Reactions: navguy12
enwhy
90
36
Toronto
Got Nokian Hakkapeliitta R3s installed on my 18" Aero wheels a few weeks back. I noticed the limited regen right away and thought it odd, but attributed it to the cold weather limited regen at first. Then we had a day that was +18C and still limited/no regen so I started paying more attention. I did a reset of the computer, tried turning regen from std to low and back again; nothing helped. I also started to notice that at slow speeds the regen seemed normal but at normal in-town and highway speeds no regen. I was thinking of asking if anyone else has noticed this behaviour, so thanks for starting this thread. Sounds like my car's behaviour is exactly the same as yours.
Since I got my tires swapped at Kal Tire and I'm using my original rims and TPMS sensors, I find it strange that the car knows I've got winter tires on. I could see Tesla programming for limited regen when roads are possibly poor, but why at +18C? And it strikes me as *really* odd that someone who has winter tires gets limited regen, but someone on the same roads in the same conditions, but with all-season (or even performance!) tires would still have regular regen. They'd be the ones far more likely to lose traction from stronger regen. Odd programming decisions. I guess that's what you get when you have Californians coding software for cars in a Canadian winter.
I have done exactly the same. Swapped R3s at Kaltire Vaughan this past Saturday on stock 18" aeros. Noticed no regen, reset, changed the regen settings. Same experience.
thesteve
192
124
Toronto, canada
We need @elonmusk to fix lol. Should be easy for them to replicate by swapping tires to winter conti or r3. Can’t one pedal anymore :( although I suspect I wouldn’t be able to do that in winter anyway
daranello
23
10
Northern Ontario, Canada
Winter tires are EXTREMELY soft are warmer temperatures, you can bend the rubber with your thumb. The softness of the tires in warm temp are tricking the car to think it's slipping.. once temps get colder the rubber will stiffen up and that will go away.. the reason Regen is coming back at 30mph is there is less force on the tires causing less imposed slippage..
Reactions: SageBrush and Anto
bpjod
424
1,792
Alberta, Canada
Not that at all. Most of the days I've had my R3 tires on it's been a handful of degrees below or above freezing. I've driven on both snowy roads and dry roads so that's not a factor either. Still have the issue. Also present on days where it's been warm, around room temperature. Also, regen returns below about 30 kph, not mph. That's about 18 mph.
Reactions: jsmay311
VistaM3B
71
49
Ottawa
My ReGen Brake never felt the same after V9 update. I haven't put Winter tires on yet. Whatever you guys with Winter tire reporting here I have been experiencing since V9. Still curios to know that its related to climate change or a possible bug in V9.
Darthbenji
1,003
594
Ontario
I was going to say it’s been quite cool in the gta the past week or so. Easily at or below freezing at times. Also this seems to be a model 3 issue. Not a Tesla issue. I’d assume if it was the tire compound being too soft, those same tires on an S or X would eliminate regen also. I agree it’s something with the tire that is tricking the car into thinking there is regen when there isn’t.
I think it’s obvious Tesla doesn’t know about it. They’d have an onscreen warning for it if they did just like they do when it’s absent for other known reasons.
Someone leaving a tire shop oblivious to his or her coasting machine will have an accident and they’ll investigate. I assume the telemetry Tesla gets will show no warnings, accelerator lift and no deceleration. Well, not until they hit the brake manually. Which may be too late. Model 3 braking distance just went back up it seems.
