There's a solution to this problem:
If you unplug the J1772 but leave the adapter in, the car knows about it and will not attempt to close the charge-port. Not just that, it won't let you drive away either. As far as the car is concerned, this is similar to a power outage - if you shut off your breaker to your HPWC you will notice that the car won't let you drive either.What?
Every time I unplug a charger (at home), I walk to the HPWC to hung it in there, by the time I am done, I head that the charge port closes all by itself. 100% of the time. I don't press any buttons or anything, the car does not lock (because I am nearby).
One of our cars is a non-refresh and it does auto-close, though sometimes not until you put it in drive. Try it out, unplug, and if the charger doesn't auto-close, put it in drive.No, mine is motorized, but does not auto-close. It's not a refresh car, as croman said.
You should never just unplug someone, even if you think you know they don't need it. I have free charging at work (at least it was free last time I used it, even though it uses Blink chargers IIRC). While I never charge there on regular basis, there were 2 occasions in the last 4 years where I DID need the extra charge because of the additional driving I was expecting to do after work. If someone unplugged me, that would not have been fun as I had to pick some people up from the an airport and there was no superchargers around (still isn't, coming soon since 2013, though finally got some movement this year).Leaf owner should have still asked first, but do you (or that X owner) really NEED to charge? Unless you guys have 100+ mile 1 way commutes, you shouldn't need to charge.... especially at a place that sounds like has more demand than supply of EVSE's. You're not just milking free employer charging to save a few pennies, are you?
Let the short range saps have access to the chargers. There's also these things called "Superchargers" you can exclusively use for free.
PS> To ensure yours is in fact motorized, can you CLOSE the charge port from the main screen? If not, then it's not motorized, it's just spring loaded and auto-
And it doesn't auto-close when you start driving? What's the vintage of the MS?Yes, I my charge port door is motorized.
It might behave differently (i.e. not attempt to auto-close) if:In terms of the J1772 adapter scenario, I did a little test video.
Interesting that you say that you can't drive with the adapter in place. I can with my classic S — did it a couple of days ago to adjust my parking position. The dash does warn me that my charge door is open, of course.If you unplug the J1772 but leave the adapter in, the car knows about it and will not attempt to close the charge-port. Not just that, it won't let you drive away either. As far as the car is concerned, this is similar to a power outage - if you shut off your breaker to your HPWC you will notice that the car won't let you drive either.
