vtplm
@Marco_Polo Can you take a pic of the inner wheel well on the rears? Im just wondering how they deal with the curvature.
Got my notification from Rally Armor that they are available. After looking at the install instructions I'm hesitant to pull the trigger. Can you show what they look like from the front looking into the wheel well. Seems like there will be some ugly clips showing.Met up at Rally Armor this morning to install the first official set of mudflaps. While these are identical to the set that were installed in january, the clips previously were prototypes and were not weather protected. The flaps themselves had been cut quickly for the test fit. this final-install set was properly machined with a few minor adjustments. considering i have a blue MY, i went with black flaps w/blue lettering. I love the way they came out.
The flaps will be released over the next few days. a few pictures below for those interested.
Thanks for pointing this out. Other cars I've installed these on come with brackets that sit behind the flap and allow mounting. This new clip system seems strange. Definitely need to see up close shots installed before I pull the trigger.Got my notification from Rally Armor that they are available. After looking at the install instructions I'm hesitant to pull the trigger. Can you show what they look like from the front looking into the wheel well. Seems like there will be some ugly clips showing.
nope.Will the OEM Tesla mudflaps fit in the rear wheel too?
If you installed the sort-of molded ones, then they shouldn't. I've had my front ones on for months and no issues, although they aren't totally effective at keeping shmutz off the bottom of the rear doors and front of the rear wheel well.I just installed mud flaps on my Tesla MY yesterday. They look very nice and sporty. One thing, I am worried, will the mud flaps hit the road surface? Mine are low profile and purchased from Amazon. I am sure the Tesla OEM will hit the road surface because of the clearance.
Pics?I just installed mud flaps on my Tesla MY yesterday. They look very nice and sporty. One thing, I am worried, will the mud flaps hit the road surface? Mine are low profile and purchased from Amazon. I am sure the Tesla OEM will hit the road surface because of the clearance.
yes, I installed the molded one. I guess, they should be fine.If you installed the sort-of molded ones, then they shouldn't. I've had my front ones on for months and no issues, although they aren't totally effective at keeping shmutz off the bottom of the rear doors and front of the rear wheel well.
Which ones did you buy?yes, I installed the molded one. I guess, they should be fine.
I have similar mud flaps, the issue is that the front right side will not sit flush to the body.CUSIYU Tesla Model Y 2020 2021 Mud Flaps, 4Pcs Front Rear Mudguard Splash Guards Fender Mudflaps Fit for 2020 2021 Tesla Model Y Accessories
They sit flush, like OEM I will take pictures when I got home. These are made in China and the first one I ordered, they comes with 6 pieces long rivet, I ordered another one and they comes with 8 piece short rivet. I used the short ones for rear and long ones for the front because the short ones do not work for the front. I could not press the pins. I will return the other one. If you plan to buy these brand make sure you get the long rivet about 2.5 times longer than the original one.I have similar mud flaps, the issue is that the front right side will not sit flush to the body.
Mine don’t. ((They sit flush, like OEM I will take pictures when I got home. These are made in China and the first one I ordered, they comes with 6 pieces long rivet, I ordered another one and they comes with 8 piece short rivet. I used the short ones for rear and long ones for the front because the short ones do not work for the front. I could not press the pins. I will return the other one. If you plan to buy these brand make sure you get the long rivet about 2.5 times longer than the original one.
I can see, there is a gap. It may be hard to remove it, correct? Bend the flap and re-install. Mine does not look like that. If you press it, will it stay flush or back to the same position as the picture?Mine don’t. ((
If you press it it goes back to the same position.I can see, there is a gap. It may be hard to remove it, correct? Bend the flap and re-install. Mine does not look like that. If you press it, will it stay flush or back to the same position as the picture?
It is bad design. The issue with mud flaps, they are hard to remove.If you press it it goes back to the same position.
I’m still thinking about going with Rally Armor. Not having much luck with the molded ones.The Basenor flaps are around $40 and they fit flush. Easy to install - just don't totally unscrew the nut on the bottom.
I think, Basenor mud flaps use clips, I try to avoid clips because they can be rusted.The Basenor flaps are around $40 and they fit flush. Easy to install - just don't totally unscrew the nut on the bottom.
